Just wondering if 2750 has the most Maccas of any Postcode? Ever counted?
I know Krispy Creme did a lot of research into the best location for their first store(high percentage of fatteh's); hence it's appearance in the 'Riff.
So us fatties also have Golden Arches at
*Kendall St
*Mulgoa Rd
*Penrith Plaza
*Old Bathurst Rd
*Castlereagh Rd
...all in 2750
...not including Werrington, Cambridge Gdns or Glenmore Pk
SHAME,Shame on us!!! Lol
lol youve got the one outside panthers, the high street, westfields and the new one on peach tree rd. Then youve got emu plains, 2 in stmarys, 1 in st claire... so much delicious heart disease in the area!
dont forget the one in Cambridge gardens ;)
St Clair Represent :) probably driven past or herd you go past my house a few times. Next time you drive in saddington st st marys when you slow down for the spped hump at the school just give her a little boost. Ill see it from my balcony haha.
  • 3 weeks later...
Cops just chased someone into my building > entered the office next door > then mine > we went down the hallway.
Found him hiding in a cubicle.
Welcome to Penrith!
Maybe this is a new job seeking technique?
"Nah mate; I has been werkin' here for aaaaages..."
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
