  • 3 weeks later...
So after dismantling the entire rear brake assembly looking for this phantom vibration it turns out that the hand brake cable had come loose and was rubbing on my tail shaft. All fixed and no more random noises ;)
  • 1 month later...
  • 3 weeks later...
Ok so can mark a few things off that list, last week I picked up:
*a cusco 2 way diff with 4.11 gears (currently has 3.58)
*r32 Gtr callipers and slotted rotars front and rear (same as 33 gtst I believe)
Gave the diff a clean up and painted the calipers red for 20 extra killawasps
    • Learned a bit @PranK To add a twist to this take, I've done some further investigation and turns out I don't know if I even have coilovers. I have Mugen Showa on all corners, which appear to be struts / springs online. Someone may be able to correct me if I'm wrong.
    • Well, i've been told it's going to be in Poland around october - november. It should set off by the end of this month. Waiting for it to arrive is the easy part, searching for the right car, wake up in the middle of the night to see the photos and decide whether to bid or not - that was difficult
    • Thanks mate, i'll keep that in mind. Not sure though if the black carpet will fit grey interior. I'd prefer original Stagea set but if i fail to find one in another few weeks, i will probably come back to you. p.s. - is this original, licensed Nismo product?
    • I'm a strong believer that old sports cars should be reserved as weekend cars and owned by mechanically inclined people. The risk-reward ratio is only acceptable under those conditions.
    • @Stringycheese hopefully this is helpful. 🤣
