Hey my fellow SAU'ers
I am having an IDLE problem with my Stagea 260RS S1 that has RB26DETT on it.
The idle goes up and down and not stable between 1500rpm down to 200rpm and sometimes stalls especially when called.
We have checked the AAC valve.. and cleaned it aswell.
I have read somewhere that TPS can be another issues and need to check the voltage, I have a datascan but I dunno what values i should be looking at.
We have tried swapping Air Flow Meters with my mates RB26 R34 which doesnt have any idle issue and plug it in to my Rb26 and it still doing the same behaviour.
But what myself and my mate notice is, when we pull out the plug out of the water temp sensor that goes to the ECU and the idle started to be stable around 800-1000rpm range.. But ones plug back in.. the idle goes up and down again.
We have tried swapping the water temp sensor with the R34 one, idle still the same, going up and down.. but we notice the part number is different on this RB26 water temp sensor compare to mine.
Is there anyone can give me information and point me to the right direction what else should I test and check?
Would be much appreciated!!
Cheers Sau'ers
https://www.sau.com.au/forums/topic/422233-stagea-260rs-rb26dett-idle-issue/
  • 4 months later...
    • If we're going after market gauges, I'm a big fan of Australian made... Get some RedArc!
    • Unless you're fortunate enough to buy a newer car, getting an older style plate to match your name/car is difficult because they've already been purchased.  Unlike other countries, personalised plates are locked to the country and not region, so there can't be multiple versions of the same plate but with a different area code.  Hope that helps
    • People use the numbers to make it look like letters to spell words/names, which is where the illegal spacing comes in. For example this GR Yaris
    • Today's rock removal from my stock pile out the back into a 4m³ skip bin, I still have a bit to go, hopefully there's enough room in the skip bin, it will be close My daughter and her boy was coming on Sunday to help, but, I got possessed by demons and started work as soon as the bin arrived at 1230 today Lots and lots of barrow loads were achieved  Currently I'm sitting on the lounge drinking beer thinking of how I should have waited till Sunday for some help, tomorrow will be a day off, in saying this, my day off will involve prep and paint of my alloy coolant and PS tanks with wrinkle paint (Jackie is in Sydney till Sunday so the home oven will get a run curing the paint....LOL)
    • That's why I said it is a meaningless term. Because there is more than one meaning that people can apply to it. When we said "highflow", that is exactly what we mean, and exactly what is done. In a highflow, they take your housing and machine them out to take bigger wheels, have a better internal profile, etc etc, and fit a new core with the different/better/bigger wheels.
