Hey everyone,
I am wrecking a S2 R33 GTS T so have a whole heap of spare parts ready to go!
Check out this list below for parts and prices, if there is anything that you need but don't see here then just ask. I may have it.
R33
S2 Rear cradle inc drive shaft/brakes/cables
$200
S2 R33 Doors
$150 each
S2 R33 Boot with spoiler and hinges
$200
S2 R33 Bonnet
$300
S2 R33 Front Seats
$80
S2 R33 Rear seats
$35
R33 Rear Bumper
$100
R33 Stock Cooler
$80
R33 Front Rio
$50
R33 RHF Guard
$100
S2 R33 RH Side Skirt
$50
S2 R33 Door trims
$20
R33 Switch pack rits
$50
RB25DET Ignition coils & Plugs
$100
R33 RHF Fog Light/Indicator
$100
Seatbelts
$50
RB Radiator
$20
S2 R33 Headlight
$400 pair
S2 R33 Grill, Skyline Plate
$30
S2 R33 Centre Console
$30
S2 R33 Tail lights
$500 pair
S2 R33 Washer Bottle
$20
S2 R33 Coolant overflow
$20
S2 R33 Rear pods
$80 pair
S2 R33 Glove Box
$30
S2 R33 Boot insert
$30
S2 R33 Speedo
$50
S2 R33 Centre Dash
$50
S2 R33 Dash Surround
$50
S2 R33 Windscreen Wipers
$30
S2 R33 Suspension
$100
S2 R33 RH Control arms – Upper & Lower
$100
S2 R33 Rear steering rack
$50
S2 R33 Rear Strut
$50
S2 R33 Door Inserts
$50
S2 R33 Parcel Tray
$50
S2 R33 Air box
$150
S2 R33 Break Booster
$50
S2 R33 Hand brake
$40
S2 R33 Clutch slave & Pedal Box
$50
S2 R33 Front Steering rack
$50
S2 R33 Front Cradle
$100
S2 R33 Sway Bar & connection part
$70
R32
R32 Diff
$300
R32 Front Brakes and vertical link
$200
RB20DET Engine no loom
$400
Rb20DET Gear Box
$200
All prices are negotiable, make an offer. Need these parts gone!
Cheers,
Leong
0401 526 517
[email protected]
Do you have a front strut brace ? also i am interested in door trims and other interior bits eg sun visors etc if in good not faded condition can inspect tomorrow afternoon
  • 1 month later...
    • Welp, good to know. Will have to wait awhile until steady hands with drills and taps are available. In other news, these just arrived! I will weigh them for posterity.
    • 100% the factory sender is tapered, that is how it seals (well, that and teflon paste or tape)
    • Thanks folks - I've saved a few links and I'll have to think of potential cable/adapters/buying fittings. First step will be seeing if I can turn the curren abortion of a port into something usable, then get all BSPT'y on it. I did attempt to look at the OEM sender male end to see if it IS tapered because as mentioned you should be able to tell by looking at it... well, I don't know if I can. If I had to guess it looks like *maybe* 0.25 of a mm skinnier at the bottom of the thread compared to where the thread starts. So if it is tapered it's pretty slight - Or all the examples of BSPT vs BSPP are exaggerated for effect in their taper size.
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
