K my 32's oil pressure gauge is showing low pressure. It should be on bout 3kg/cm2 at normal driving with out reviving too hard but its dropped to 2kg/cm2 according to the gauge. The motor has a lite ticking sound too now and this morning when i started it , it sounded like a wrx so i guess it was missing but that corrected itself during the drive.
Has anyone got ideas? I have a few of my own but other opinions would be good cheers
https://www.sau.com.au/forums/topic/422424-rb20det-low-oil-pressure-help%C3%97/
get a 20 dollar oil presure guage and 50 dollar sandwich plate and install it........
the standard gauge is a piece of shit and over 20 years old. my 33 had the exact same issue... made me think everything was going wrong...
put in cheap set of gauges and bobs your uncle. car is actually fine.
But also ask the obvious questions too like:
- When was it last serviced?
- What oil and filter do you use?
I only use Castrol Edge 10W60 and I was unable to kill a 20 bottom end. Also, only use Nissan filters. There is a big difference in the pressure drop and performance of many cheap aftermarket-repalcemetn filters. I always got better pressure with the Nissan filters.
I am pretty sure the std oil pressure gauge is just a Bosch unit so are cheap to replace. I put a tee into the block and run the std oil pressure gauge to the dash and the second tapping is for my aftermarket oil pressure sensor that is hooked up to my data logger.
Mmm gauges r a good start but the motor has developed a noise too n it wasn't firing all pistons this morning. Hopefully all coincidence. Its not blowing smoke or burning oil. And important not sure how u install an oil pressure gauge,
its due for next oil change next month. Last oil i used was 10w40 penrite full synthetic with ryco filter. Used to run 5w30 Castrol but the mechanic said i should use 10w. Car definitely felt more responsive with 5w30 though
Bin Ryco oil filter and only use genuine Nissan. Put 10W-60 Castrol Edge in it and I am pretty sure that your problems will go away. Wouldnt hurt to put some diesel oil in it for 500kms then dump it and put good oil in.
Basically diesel oil has a high level of detergeants in it so can help clean gunk and build up out of the oil. Noisey lifter coul dbe just a sign of things getting abit glunked up in there. I used to put a high detergeant flush through my oil system every 12-18 months. Never seemed to hurt and helped keep the engine clean. Probably overkill but since I did track work and got the oil pretty damn hot...i used to just do it as housekeeping
I ran 500ml auto trans fluid in mine for 10 minutes before dumping the oil last time..
Now THAT cleans it good.
and agreed.. Catrol 10w60 is what I use.
Can you tell where abouts in the engine the ticking is coming from?
mine has a lifter noise at first cold start..
goes away soon after though.
Take the car to someone that knows the tricks of the old girls. Otherwise some mechanics may try to tell you the sky is falling for something rather simple. As others have said there is nothing obvious that would suggest a miss and tapping noise is a problem.
Thyere is a 30-50% chance its just a tired coil pack and the engine is a high km engine that hasnt always had good servicing and oil put through it. How long have you had it and what is the history of the car.
The gooid news is that they eat up high kms, take a hell of a lot of abuse and you dont harm the average engine.
Theres nothing wrong with the ryco filters and there alot of people that use them with no problems.
I concur with all of the above. The failure of the factory gauge is a well known common one. Mine has only just started playing up in the same way. Apparently there is a solder joint in them that needs a rework and they come back, but I haven't had mine out to have a look and prove that.
I would argue that Ryco filters are fine. Have always used them on every car I've ever had and never had cause to doubt them. Nissan ones may in fact be better, but there's nothing wrong with Ryco.
If you are not having problems with them then I guess there is no reason to change. I use std Nissan as after about 3,000kms there is always a reduction in oil pressure in my engine when using the Ryco and the other Autobarn etc filters. With the std Nissan the oil pressure barely changes to the point that I only really change them every 10,000kms. I have tried the K&N and other exotic $20 jobbies and cant tell the difference between Nissan OE.
The NIssan filters are also cheaper...thats important to me :)
Coils are splitfire with ngk plugs. In any case the car might just be a tepremental female because i made this thread this morning and beside the gauge, everything felt good when i drove it at lunch this arvo. The test will be how it acts tomorrow morning.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
    • The video for the servicing and fuel filter change can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44 One of the main jobs I wanted to do before the car officially went on the road, was to remove the awful looking blue silicone hoses. There's nothing wrong with having coloured silicone hoses, but I realise as I'm getting older I prefer monotone engine bays with a splash of colour on the engine cover(s). I cover this in a lot more detail in the Youtube video, so unfortunately there's limited photos of the process. The intercooler, upper radiator, boost vacuum and upper breather hoses were all changed to black silicone with mikalor clamps. The only blue left is a blanking cap at the back of the inlet manifold and the GReddy pulleys (which will be replaced for stock when the cambelt gets replaced) While the intercooler pipes were off I gave them a quick clean/polish too A before photo I do have a replacement air filter on its way. Fuse box covers were painted blue, they're now satin black Another job on the list while the bumper was off, is to add some mesh https://live.staticflickr.com/65535/54737966256_99b28bfa30_c.jpg[/img] I was hoping to use some thin wire to secure it, but it seems I've misplaced it and the wire I had was too thick to twist easily. I ended up using cable ties for the time being https://live.staticflickr.com/65535/54737131882_c2b7989dcc_c.jpg[/img] Was pleasant to see this https://live.staticflickr.com/65535/54737131627_8b2aab13b3_c.jpg[/img] The last thing to do was to fix the front grill and re-mesh that to match but I ran out of time The Youtube video can be seen here: https://www.youtube.com/watch?v=R4FsF6tgizE&t=23s
    • Hi all,I already introduced myself in the Victoria section, but only saw this section now lol XD New to forums and new to skylines. Hoping to buy my new skyline within October
