So i got epa'd a couple weeks ago. Got a letter in the mail after i passed a highway patrol car in 5th gear going at about 50km/h -_-
I was naive enough to leave the stock exhaust at the place where i got my exhaust done, so i don't have the stock system anymore.
Does anyone have any suggestions other than repurchasing a stock system? Or has anyone been in the situation before?
My exhaust goes from the tips to the cat but my cat is still stock.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/
i've got a butchered 34/33gtst muffler with na piping if you want, should fit, since it fit in my gtt. i'm in burwood though. will loan for like maybe a 12mm ratchet spanner or a rock from your garden or anything like that.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6798829
head to the vic section, and ask if you can borrow someone's
plenty of nice folk around, it's been done before
Alright, thanks heaps mate! Will ask
Haha sounds good, you live around 40 minutes away from me, I'll try to source out a closer one, if not i'll temporarily swap my garden gnome for your exhaust ;)
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6798999
A friend of mine has been driving around with no cat for years, pretty loud and even backfires, stock silencer is the only thing he says puts off the cops, only advice I have to impart if your exhaust is on the edge of legality.
good luck mate
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6802397
And how can he have no cat unless its a de cat pipe. Which your ass is grass if<br />U get caught with that shit. Because the skyline cats are metal inside so u can't punch it out !!!
I've mentioned it quite a few times to him that in no way is the power/noise benefit worth the penalty, his dumbass reply "Test pipe mate" lol
To be fair, he drives like an old lady all the time... cops don't notice you unless you drive like a dickhead.
Edited by NewGenMo
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6803724
Highway patrol are terrible when it comes to imports!
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6805290
So how did those methods go with passing?
Sorry i didn't get to reply, what i did was i grabbed a steel plate and cut out the stencil off the gasket in between the cat and piping, i then drilled a few holes into the stencil and replaced the gasket with that steel plate(stencil)
Made me slower than a daihatsu charade but it made my car sound like my aunties camry.
I just passed at 88dB!:)
Which means that pretty much anything aftermarket, in relation to exhaust, is illegal, so guys even if you think your exhaust is illegal, it's not.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6805299
Yea but they gotta lay of the imports there a Japanese car, it's very stressful to cop a defect. And harassing young drivers because they own a import is not very good. Some of us just love cars and not everyone is a hoon, I think they don't understand that the imports are
Gonna be quicker off from lights even when taking of slowly due to there diff gear setup. But yet that's no excuse for hoons I saw this dickhead there other night doing 160k, down Victoria street Wetherill park in a s14 silvia now that deserves a defect.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6805301
Thing is they won't, now that the car scene is so huge in Australia, it's extra money for them, highway patrol get commission from EPA for example, cops would rather get money of an import driver than an aussie car driver, which sucks!
And yeh hooning is stupid, only a select few spoil it for the rest of us.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6805318
You can it just takes f**king ages, then there's a metal brackety thing welded inside the middle that will vibrate and rattle and at 2-3k rpm will make your exhaust resonate with a strange sound.
https://www.sau.com.au/forums/topic/422583-so-i-got-epad/#findComment-6805529
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
