Hi Guys,
My name is Vince and over the weekend I picked up my first Skyline. I've been on the forums since September last year now researching about Skylines and this is my first real post on here. I bought the car formerly known as FLN57S off Jason and am loving it to bits. It is a 1998 GT-T in the dark blue pearl colour This is my first turbocharged car so i'm still learning a lot but am enjoying this new experience. I'm from St Clair so that's Penrith region for those who are unfamiliar Western Sydney
The car as I bought it had fitted:
Mechanical
- 3in front pipe
- Hi-flow cat
- HKS Silent Hi-Power cat-back exhaust system
- GReddy front mount turn flow intercooler
- A'PEXi pod filter
- Spitfire coil packs
Electronics
-Nistune chip
-Blitz Spec R dual solenoid boost controller
- A'PEXi turbo timer
Suspension
- Tein Flex coilovers
Exterior
- Origin front lip
-18 in wheels
- LED tail lights and middle brake light
- HID's
- Nismo front indicators
Car Audio
- Clarion DVD headunit
- Panasonic 4 ch amplifier
- Kenwood 6in rear speakers
- Kenwood 12in subwoofer
It is tuned and running 10psi.
I'm extremely happy with how it is now and don't have any major plans to modify it mechanically currently as this is my first turbo vehicle and i'm still getting used to the power.
Since taking ownership I have given her a good clean and degreased the engine bay. I swapped over my own custom plates and went to Carbon Car Systems to get an alarm & immobiliser system installed. Thanks to Daniel and the guys at carbon for doing the install, they did a great job and I would highly recommend them!
I've also got a Rockford Fosgate P2 12in sub and Rockford Fosgate PBR300X1 amp waiting to go in from my previous car. So far only plan to upgrade the sound system with JL Audio C2 splits up front and coaxials in the back and run a JL 4ch amp with an Alpine double din screen head unit.
In the future possibly upgrade the turbo but not really thinking about that just yet, i'm happy with all the bolt-ons and aesthetically I love the simple look. Just thinking about returning the tail lights to stock and later on getting some nice japanese wheels.
Here are some pics of when Jason had her:
Photos from the MTA inspection:
When I picked her up:
901438_10152700515230198_1347706032_o.jp
After first wash:
New Plates (BTW My nickname is Toby hence the plates):
894937_10152706724130198_1260364346_o.jp
And my previous rides:
405585_10151066035635198_1406754990_n.jp
Thanks for looking guys and I look forward to learning more about my car from reading these forums and hopefully attending some events
Cheers
Edited by GoldZilla
https://www.sau.com.au/forums/topic/422940-new-skyline-owner-in-western-sydney/
Welcome Vince.
I remember that car - a nice ride it is.
Can you PM GoldZilla and ask him though to delete the brand of your ******?
There's a thread about us SAU fellahs in the Penriff area, so feel free to contribute to that.
I look forward to seeing this car - and yourself!
Welcome Vince nice car! I'm also from St Clair. Might catch you around. There is a western sydney event in the NSW section for Saturday night if you're interested in joining in.
Enjoy your new ride!
The boys at CCS are brilliant - did my daily, and it's a frigging immaculate job.
Couldn't agree you more man! Awesome guys!
Oh awesome! Yeah hopefully catch you around. I'll see if I can drop by as I have a birthday party on that night but it is in the Penrith area anyway so I think I can swing by for a bit.
Definitely get stock lights. Will improve the look by that much more. I had similar lights on mine when I got my car except mine were even more faded, almost pink. Looked disgusting. Change them ASAP!
Yep mine are pink now haha! Eyeing some on ebay now.
Make sure to come to Texi in June, get a good feel for how the car handles/performs (and keep it off the roads!)
Yeah I just saw the event and read the introduction to what a texi is. Looks like stacks of fun from the video. Might come and spectate that one and see what the go is. A bit nervous to get out there.
  • 4 weeks later...
The police are gonna love you now welcome my friend !
Hahaha So far I haven't had any hassles. *knock on wood*
My dad fabricated a shroud for my filter over the weekend. I'll get some pics up soon.
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
