Intake done in December. I think the ping was before the intakes went in.
Even if it was after...wouldnt the ECU be picking up the different intake and adjust accordingly? I reset the ECU a couple of times since then.
Ping only at low revs...1.8k to 2.3k? higher revs/speeds no ping.
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6809879
Nope, have not changed spark plugs/fuel pump at all.
Got the car Nov 2012. Car is a 2007 V36. Got it with 36k kms on the clock.
I'll try United P100 and see what happens. Will try to clean MAF and throttle body on the weekend and proceed to spark plugs and fuel pump if all fails...
Is there anything I am missing? Should I try stock air intakes?
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6809912
Maybe try running some Subaru upper engine cleaner through it? Get rid of some gunk built up in there (and give you a nice clean intake manifold while you are at it - might not fix it, but for under $20 it is worth a try) My V35 ran beautifully afterwards
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810137
It also depends on where you bought it as to whether it really has 36k on the clock - it costs under $100 to get this changed. If you have more km on the clock, there are other things that could be more built up in the engine or things that could be wrong. Obviously at 36k it should be basically a brand new car ...
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810198
Ok ill try checking the AFM and the cleaner. I dump in Nulon Fuel System Cleaner and 44l of P100 last night. Lets see what happens over the next few days.
I bought the car on auction from Japan. It was checked for genuine KMs by computer system. Whether or not it's genuine, can't really be that sure but yes essentially the whole car looks brand new and nothing was modded or been touched.
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6810623
Could the the timing yes, one of the more common causes...
Mine has zero mods, its just my daily and I haven't had it for long, but being a high comp engine with Japanese ecu tuning I'm not hugely surprised by the ping on crappier fuel. But I will look at spark plugs and intake clean soon
The Mirage on the other hand has been driving me nuts. I have changed the plugs, plug leads, dizzy cap, rotor, fuel filter, air filter, checked the timing, three rounds of intake cleaning (two at home and one with a pro machine) and full bench injector clean with new o rings etc... yet, still pings :rolleyes:
Next step - colder plugs and oxy sensor. No luck with cheap OBD2 adaptor either
https://www.sau.com.au/forums/topic/423199-ping/#findComment-6813062
    • Where is the warning "That this thread is super old"   I just went into a 5 year old thread, went to do a reply, and couldn't see anywhere obvious a warning of it being super old
    • Duncan is correct. Pitwork (and Toyota's own cheap brand "Drive Joy") were primarily created as brands to sell other manufacturers car parts. It would be weird if Nissan sold parts for Toyota vehicles with a Nissan logo on it, so they created Pitwork to sell parts for other brans Toyota, Honda etc. They are not the same as Nissan genuine parts, although they *do* meet Nissan's standards for replacement parts. They aren't supposed to be a substitute for genuine parts, but a cheaper alternative that is better than Ebay fake parts from you-know-where.
    • Thanks GTSBoy, much easier to work with it now it's free!
    • I _think_ that one has a christmas tree or some other retainer spike into a hole in that panel under it. Come in under it with thin scredrivers and just pry it gently up. If you rip the ears off the retainer pin....so what? Just stick it back down after with a bit of race tape and carry on with life.
    • Here's a pic of the damn thing
