The first thing i would do is remove the blow off valve and relocate it to the bin! Then i would jump on the search function and find the modifying guide which will give you every bit of info you desire :yes:
He speaks the truth. I bought one stock. And i've spent more than enough to buy a GTR easily now.... and it's only just begun!
I bought a modified one and could probably buy 2 GTR's with what i have spent :P
  • Like 1
Recently bought myself a stock r33 gtst with a blow off valve,
What would be the first thing you would upgrade in the engine bay? What do you guys recommend?
Thanks, Mark.
Upgrade to stock BOV
Thanks, Mark.
firstly the R33 is the best bang for buck Nissan on the market today...so congratulations and welcome to the cool club
now...buy a 3 inch bellmouth dump pipe form jjr...200$ great budget mod....get turbotech boost tap for 45$ turn boost to 10-11psi....get copper plugs gapped to 0.8...change all filters and fluids if not done already....this should net you around 180kw on a healthy car and keep you amused for a good while you sort out brake and suspension mods and the reliability of the car in general, at some point install a decent intercooler.... after a year or so you should know that the car is reliable and if its worth spending money on, have all its little issues sorted and have a good feel for how to drive it, save about 5k to start with....then you aim to build a 300kw car ( aim for 280-320 its about as far as you can go and maintain some traction, reliabitiy and stay budget friendly) , it will cost over 5k no doubt...but how far over will depend on how handy you are with the spanners ;)
My build with mostly new parts from stock has been less than 10k including clutch, tuning, and alot of custom fabrication...it has enough grunt to keep up with the best of em...i imagine you haven't paid anymore than 10k for an r33 so for under 20k you can have a car that will beat or at least keep up with just about anyone out there.....you will not buy a good GTR of any description for under 20k, that doesn't need more money spent on it and if built right the humble GTST can easily keep up with alot of GTRs out there, you may even beat a few....So don't listen to these haters..as long as you havent bought a lemon..you're on a winner GL :thumbsup:
  • Like 1
I recommend to use the search button. But because I'm feeling nice I'll give you a basic quick rundown.
1. A good free flowing K&N panel filter.
2. Bin bov and use a stock gtr bov.
3. Buy a plazmaman intercooler kit.
4. Buy a 3" turbo back exhaust
5. Greddy profec b spec2 boost controller.
6. Hypergear hiflow turbo or equivalent.
7. Adaptronic ecu/ injectors/ tune.
Thats a quick basic rundown mate. Just that there is probably close to 5-7k mate so be prepared. You'll also want to do suspension brakes gauges wheels and the list goes on. I've got a HKS 2535 for sale which would be a ideal turbo upgrade as the standard turbo is rubbish.
5.
Edited by Joshbigt62r
I also recently bought a nearly stock ECR33. Nearly, as it came with a 3" exhaust, pod filter, neon lights and amp.
To give you an idea, here is what I have done:
- Removed neon lights and amp
- Brake rotors and pads
- R33 GTR wheels with Dunlop Direzza Sport Z1s
- Refreshed stock suspension
- Replaced all worn bushings
- Wheel alignment
Here is what I still have planned over the next 1-2 months:
- Flush all fluids (gearbox, diff, coolant, oil, brake) and replace with good quality stuff
- Spark plugs, clean AFM and tape up coil packs
- FMIC
- Oil cooler and filter relocation
- Fuel pump and filter
- Gauges so I know what's going on in my engine
- Accusump
- Power FC + tune
My focus is on reliability as it'll be tracked throughout the year.
- Wheel alignment
- FMIC
- Accusump
- Power FC + tune
hey mate how big of a job was doing all the bushes...pretty sure mine are all ratshit...did u pay someone or do it urself? cheers
You would need a press or some handy tools to do them!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
