To bulk i like to take 15 raw eggs in the morning
tho not through the mouth if you get what i mean
P.S Trozzle i like your bike man have they got a version for men
Come on man, enough in this thread... Take it to Wasteland and troll away :)
Yeah, that was actually a pretty poor troll attempt. Calling me out on my bike, which is actually a pretty damn decent sports bike as it is lol.
If you're just trolling, well done. If you're being serious and somehow deluded into thinking you're funny and making good calls, you best climb out of the hole you're digging while you can still reach the surface.
  • Like 1
I think i love you man
No homo
Meet you there
Edited by Tommmay
  • 3 weeks later...
  • 11 months later...
