Postage: Available at buyers cost, but prefer local pick up.
Contact: O4O29O2759
R33/ S14 Nismo 2 way diff in housing - $700
post-27843-0-08145400-1367293630_thumb.jpg post-27843-0-31639100-1367293622_thumb.jpg post-27843-0-79359900-1367293615_thumb.jpg
R32/S13/180sx Nismo 2 way diff in housing - $700
R32 GTR Grill - $130
Apexi SAFC - $200
Bolt on Spacers
30mm - $100 (Pair)
15mm - $100 (pair)
Recaro Seat - $400
post-27843-0-96439400-1367293455_thumb.jpg post-27843-0-16033100-1367293463_thumb.jpg post-27843-0-00137700-1367293472_thumb.jpg post-27843-0-51438900-1367293479_thumb.jpg
XXR526 Wheels - $1000
Brand new, have fitted tyres but they will be removed before sale.
17x9 +25
17x10 +20
SSR Wheels - $600
17x8 +32
17x9 +38
post-27843-0-73966000-1367291937_thumb.jpg post-27843-0-16174700-1367291945_thumb.jpg post-27843-0-04210700-1367291952_thumb.jpg post-27843-0-77095900-1367291959_thumb.jpg post-27843-0-02498300-1367291967_thumb.jpg
Nismo Wheels (Full set of 4) - $600
P1 Buddyclub (Pair Only) - $250
17x8 +32
Wheels - $1000
17x9 +32
17x10.5 +23
post-27843-0-40994000-1367293587_thumb.jpg post-27843-0-69796800-1367293597_thumb.jpg post-27843-0-48061400-1367293608_thumb.jpg
R34 Turbo Coupe Nismo Coilovers - $800
post-27843-0-75890500-1367293492_thumb.jpg post-27843-0-62285100-1367293504_thumb.jpg post-27843-0-85857800-1367293513_thumb.jpg
R34 Reverse Lights - $50
R34 Front upper CUSCO Camber Arms - $200
R34 Return Flow Intercooler - $450
post-27843-0-44531100-1367292354_thumb.jpg post-27843-0-58019600-1367292361_thumb.jpg post-27843-0-06411500-1367292369_thumb.jpg post-27843-0-73774900-1367292376_thumb.jpg post-27843-0-94460500-1367292383_thumb.jpg
R34 Boot Sub Box - $100
post-27843-0-54875100-1367292470_thumb.jpg post-27843-0-97123900-1367292476_thumb.jpg
Rear Window Spoilers - $200 Each
R32 GTR Mushroom Pod Filters - $200
R32 GTR Apexi Super Intake Pods - $220
R32 GTR Brakes, with Project Mu pads - $550
Front and Rear - Pads, Rotors, Calipers, Drum Rear Handbrake Setup
post-27843-0-66284000-1367292209_thumb.jpg post-27843-0-49004400-1367292216_thumb.jpg post-27843-0-75183800-1367292222_thumb.jpg post-27843-0-02032800-1367292229_thumb.jpg post-27843-0-46427900-1367292235_thumb.jpg post-27843-0-68147800-1367292241_thumb.jpg
HKS 3540 - $700
Straight bolt on for RB20/RB25
Lines have been removed since photos and are not included
post-27843-0-90962600-1367291919_thumb.jpg post-27843-0-65552000-1367291924_thumb.jpg post-27843-0-91278600-1367291930_thumb.jpg
R32 Type M Plastic Side Skirts - $100 (pair)
R32 Type M Plastic Rear Pods - $70 (pair)
R33 Rear Subframe -$250
Complete with brakes, Driveshafts
Minus Diff (picture Stolen from google)
Edited by JiN_MaN
hey mate
for the return flow intercooler, are you willing to separate the piping? Is the piping a good fit for the 34? and also what is the diameter of the pipes?
I may still be in for the camber arms...though I can't be sure quite yet until I get the car into the shop (nearly there!)
Sorry not willing to separate the front mount.
If your worried about the damage on the fins, its only on the cooling fins and will make no difference to the performance of the core.
Edited by JiN_MaN
the rear window spoiler, are they for a 34? got a pick?
It would probably help if I said what spoilers I have.
Vanquish = R34, S14
Origin = 180sx
Ill grab a picture and put it up.
nope not worried about the cooler, i want the piping that's all..
Vanquish = R34, S14
Origin = 180sx
Actually I Have
S14, S15, R34 (4dr), 180sx
Sorry no R34 (2dr)
Ahhh geez, you'll make me blush,
I've got two sets, 1 black, 1 silver. I run the silver on my 32, ill grab a picture and post it to show fitment and a photo of the wheels.
Edited by JiN_MaN
  • 1 month later...
Vanquish = R34, S14
Origin = 180sx
sedan or coupe for the R34,
To suit Sedan,
Cusco camber arms, SOLD
R33/S14 Nismo diff, SOLD
R32 GTR Grill, SOLD
15mm Spacers, SOLD
Edited by JiN_MaN
  • 3 weeks later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
