  • Replies 70
was nice to meet Jag33...yeah it was Daniel...:P...anyway hope u had fun cause i sure did and will be up for it again....my time was nothin like urs but now that i actually know what im doin and how them bloody lights work i might be able to do better next time...
So what did you end up getting Daniel? :P A High 13 or Low 14? 12?
best i got last year @ heathcote was 13.8 @ 101.5mph, only had cat-back exhaust then a pod and [boost maybe 12psi max]. I probably should have turned the boost DOWN more, too much wheelspin in 1st gear :D
You should be able to get to mid 13's fairly easy with that Terminal Speed! I am hoping for mid 13's on my next outing too...
Da bunny in da grey GTR at calder hjahaha BIGGEST BLEEDER MICROSOFT SALES PERSON EVVAAAAAAAAAAAAA
haha, bunny...
nah, all da boys were out wif their vls. my cousins cousin was dere wif his yellow bt1. they were sik. but i didnt see many skylines running fast times? i think the fastest skyline was still slower den the slowest vl turbo.
    • It's almost certainly a reluctor generating an "AC" waveform. No, ECUs don't generally read those - they're usually set up for PWM square wave 0-5v stuff.
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
