Just been thinking of using multiple throttle GTR plenum. However Im not sure if the runners for a R34 and 33 are the same. I could do away with cutting the runners by machining a adapter plate using RB26 N 25 gaskets as templates. However using an adapter would mean that i have to cut and re weld the water outleet so it doesnt crush the VCT solenoid. Using 34 runners would be good because i still have the same injector sitting angle. The downside is that i cant find any 34 lower runners. So it brings the question, are the 33 and 34 runners the same especially on the way injectors sit and fuel rail mounts. From looking at a few pics they dont look the same but when you look at the gaskets, they have the same part number.
Are the manifold o rings also 14mm
Do the 33 injectors sit the same way as 34 (o -rings and sitting angle) but atleast i know i can top put on top feed injectors on the 33 intake manifold given that i change the rail aswell. I just dont want to downgrade from an intake plenum which was better.
I dropped by Jaycar and saw a cheap set of 6000K HID bulbs, thought it would be good to restore the xenon lights so i got to task.Had to take my front bumper off to access the wires that were cut during compliance to stop the ballasts from supply energy to the light plug.
It was just a matter of connecting wires back together
But then after hours of trying to figure out what was wrong with the LHS light i swapped the ballasts and the light still worked indicating the supply cable within the light is Kaput. Not sure if i really want to open the inside of the light as its the one i use. Might just get a connector plug it onto the ballast and feed it through the side of the housing to the light
Yeh man, it's easy. Take off the 5 spring clips on the housing, and undo the two little screws on the park-light side. Remove all the plastic bits that you can, tuck all the wiring inside the housing, and pre-heat oven to 100 degrees, then headlight in for 8 minutes or so. Keep an eye on it in the oven and nothing will go wrong. Then use a screw driver to pry the lens away from the housing. If you need to pull too hard then put it back in the oven for another couple of minutes. Just do it slowly and you'll be sweet.
To put it back together, just reverse the process :thumbsup:
Whilst im waiting for the tuner to get back, I got a hi flow turbo for a steal price, as im not willing to stay at 180kw while i source out options for the turbo ill use. So the hi flow will be the super sub while I find a good contender to use. Have gone through so many compressor maps I can probably tell you the name of the turbo without even looking :P.
Im tempted to bolt up the hi flow but without tune it will probably run really bad. As for the injectors if i manage to loan a Nistune consult cable ill be able to change the injector size and latency so i can still drive it (My Daily) to the tuners otherwise ill just resort to getting it towed to the tuner.
meant as in drive it for a few weeks till the tuner is back, however I wasnt sure about driving it offboost on the day i take the car.Its certainly something i will experiment doing while i have the stocker but with the hills in my area. It will be quite interesting.
  • 1 month later...
Thats good so you just gotta transfer your stuff from the 33.Except for a few things that wont work with Neos hopefully wont be much.
Very nice man good to see you a doing a thread on the build... Thumbs up!!
I see you learnt the hard way about spending a little extra on stand alone ecu's huh? Good work keep it up
I donno if I will be building mine like yours but chasing around the same figure.If it pops I'll get another stockie and repeat and transfer. If I had known from the start I would have got a standalone only a few extra dollars.
    • The average previous owner for these cars were basically S-chassis owners in the US. Teenagers or teenager-adjacent. I often tell people that neglect is easier to fix than something that was actively "repaired" by previous owners.
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
