Guest INASNT
so is it any good though? :) (getting a GT35/40R to sit under it)
wastegate doesn't sit too high does it? going on the RB31DET in the 32 so hopefully i can close the bonnet....
Anyone got any pics of what it looks like setup??
From the pic, the turbo will sit onto on the manifold. not under, which might make everything a tight sqeeze down there.
If u can get it cheap the it might be worth it, coz cast stuff like manifolds aint the best.
1. I agree with what Roy said about it being low mount. It HAS to because of the stud pattern.
2. How much research have you done to come to the conclusion x manifold is better than y manifold?? Please explain....
and there is more room now under the manifold due to the height on the new motor :)
Sorry abo0ut the stupid question, but how the HELL does a low mount manifold sit a turbo above it????
And equal length runnners and steampipe arn't the be all and end all of manifolds. Its more about how the pipes merge into each other, then into the turbo flange. If you dont know this manifold does go 3,2,1...
INASNT, the top mount is for the wastegate. Have a look at the two runners with the bolt direction different from the other four.
The two that are different go to the rear of the block.
Bl4cK32, have you had the inside de burred/tidied up? It may be worth ceramic coating or wrapping it before it goes on too. Looks like a vast improvement on the stock item, as the gasses are merged rather than slammed into eachother.
If it doesnt fit, just get a hump in the bonnet, or even a raised vent. Would serve a dual purpose that way.:)
Guest INASNT
Look where the flange on your manifold. When u bolt the manifold to the head the flange it facing up, so the turbo will bolt on to the flange making the turbo sit ontop of the manifold. Low mount means the turbo is still sitting down beside the head not high above the cam covers.
Guest INASNT
DOH, i didnt look at the pic that carefully :)
That manifold doesent look like it will make the turbo sit high enough up to cause any bonnet closing problems
Just arrived in Australia Steve :) but some work will be done to it (heat wrap or coating) the inside looks pretty damn smooth...
A nice hole in the bonnett for the wastegate eh:D
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
