My car heats up around 10mins of driving and the starts to misfire a lot
I checked the dizzy cap when it starts and misses 2nd and 5th no spark out of here, it's a brand new cap and rotor and the dizzy isn't that old
I just need this and my cars perfect :)
https://www.sau.com.au/forums/topic/425413-car-misfires-when-heats-up/
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
