Thought I chuck up some pics for y'all
The line up (don't worry about that guy on the right he's of no real importance :whistling: )
Supra first up - forgot how much it made......
I dunno wot u talkin about brah........that VL is completely standard.......honest........ :D
the victims of the dyno................broken alternator belt (I even saw it flew off :w00t: )
in the end the boyz dedication paid off and fixed :thumbsup:
if anyone wants spare parts - this is the place to get it
was really keen to see this go - but pinging pegged it back :blush:
do I even need to comment on this!!??...........H. Rodeo 3.5 v6 FTW!
This on the other hand I will comment on though.......due to strange noises in the back (dead corpses that weren't really dead) they stopped pushing it - 142kw
All in all - very nice day
Greg got the highest power of the day, 365 KW in the Rodeo.
It was brutal!
I heard it loud and clear as on its final run I heard a strange noise................snap!
Yeah, I was staring straight at it, looked fun :)
I have some video of Ralph's car spitting its belt...much less dramatic than I remember.
I assume we will get to see the Complete video soon enough?
I understand why its the tow car now, with 365KW at the wheels the Rodeo could probably tow a few cars at once!
and do a sic skid at the same time.
Pulled out my dyno chart from when the car was tuned, i gaind exactly 10kw's!
grats! whereas ralf has lost about 10kw I think.
After converting todays KW result to Hp and comparing it to last years results I have gained 55hp :) not bad for a few hundred bucks of bolt on bits.
A good day guys!
Well my mission was a success of sorts, needed to find my issue and I did. Was happy to make 225kw before 4300rpm, just need to sort out my timing jitter issues and crank a bit of boost into it.
PS dont steal my parts
Had a pretty good morning this morning. Thanks to the guys that made it happen. I'm pretty happy with my 188rwkw (252rwhp) from my RB25 with stock turbo, injectors & ecu.
Just a couple of pic's my wife took today.
8a36104771cb8a92d07a5373bbdee244_zps50ee
768737087ec7b2039d47bfa619db3077_zps525c
937cb07e05c07300fa75aeb00075bf2c_zpsc52c
fc1e762f4da20d270840e3b3daa411a6_zpse12c
bdaf84db1207889f10b0850815ea86b8_zps4e8e
0f91be66ae462530255f377765c7bb5b_zpse13c
9227ae7b5e477fd734b23b1c136e905e_zps668c
fff01755897baf9acd936c6eee18b011_zps1f18
Thanks to all that came along today! It was a great day. We ended up having 15 cars run on the dyno with power ranging from 116kw through to 365kw atw!
The most surprising car was Tara's Supra, making 309kw atw with a stock ECU, stock injectors, Big turbo and screamer and a risinging rate fuel pressure reg. Sounded so angry!
It was good to see everyone well behaved meaning we are welcome back to EFI Performance.
Cheers for a great day guys!
  • Like 1
*Cough* 111.8kw *Cough*
Need a full results list. What did the mighty rodeo actually get? And who the fark got 365?? :O
Cheers for the good day all!
The maxima pulled a whopping 225kw at the treads!
Then on a real run was only capable of 140kw because the wheel bearings were so bad that Sean didn't want to push her. Reckons that there's at least a few more ponies there but didn't want to push it.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • BRUH, one of the biggest mistakes of my life..... and i've had plenty ;[)
    • @Murray_Calavera iam just considering options 🙂 of course it is very expensive so that why i ask here 🙂  @joshuaho96 I looked at that GCG hybrid(i remember looking at it few weeks before) So this is "that" hybrid where i send them my turbo and they upgrade the inside to Garrett stuff and then they send it back. It cost around 1200-1300 USD which is FAR cheaper than the HKS and it is what iam looking for(i just do not have experience like this...to send something off to "upgrade" ) @tylink720 that is like 150 USD turbo no? 😄 I dont think i have the "ease on my mind" with this kind of turbo. I just put over 7000k USD to "LINK" up my engine...dont want to blow it up with cheap turbo 😄     EDIT: https://www.cj-motor.com/gcg-turbo-charger-for-nissan-rb20det-rb25det-high?srsltid=AfmBOooVeOZ6CZ6r1AIv5m-KPaa6BvudIPJTY8LW78khkd-gQlsaCht9 I looked at this and it seems ok? It is that CGC hybrid and it costs around 1250 USD (with back shipping). Do any of you have experience with this hybrid on NEO turbo? I quickly look thru the forum/web and it seems very good.
