Tried searching but must be hopeless at using it. Also the 25 thread is full of small turbo results.
Have a 25 with a 3582r plain wheel turbo.
I have a full 3 inch turbo back exhaust with a resonator and rear cannon on it but I'm struggling with small amount of exhaust backpressure pushing open gate under full noise.
I am thinking the dump pipe might be a tad small With the wastegate plumbed back in. I'm aiming for 500+ (currently at 471hp).
looking at what people's opinions/experirence are on What size exhaust they have.
I have enough room for 4 inch but don't want to go oversized if not necessary.
Go with posts.
https://www.sau.com.au/forums/topic/425650-what-size-dumppipe-for-500hp/
A free flowing exhaust would just make it worse I think. You need to increase the wastegate actuator spring tension to help hold the manifold pressure in.
What is your base (minimum) actuator pressure?
4" = no restriction.
Saying that, plenty of people have made 500bhp on a proper 3" exhaust with open screamers.
Personally I'd go with a 3.5" dump to tip, magnafolw muffler and a free flowing rear can of choice... Here's the thing though, make the waste-gate dump pipe larger and longer than you might think. Run it right down and merge it just before the cat in a nice long, shallow angle transition.
i have 14psi actuator springs in. its a turbosmart 50mm gate.
I cant stand the sound of a screamer pipe so plumbback is a MUST..
the gate pipe is about 60cm long joining in just before the cat area so i think having a bigger diameter exhaust in a copy of current setup will do the trick.
I just dont want to go to hassle of doing 3.5inch only to need a 4 inch down the track
There is no oversize with a dump pipe imho. 4" will work fine.
However I don't think that's your issue, you should be able to get away with a 3". Have you tried a heavier WG spring as mentioned above?
i have changed the way the gate signal is being sent and it helped sort of. its either 16psi base and wont bleed past 21psi as a single connection onto wastegate or as a 2 port connection its 23psi minimum bleeding up to the 26psi wanted.
I would like to run 18psi low and 26psi high settings so changing the spring pressure up closer to higher settings is something im trying to avoid
At what boost? 7psi is fark all spring...
I am running 26psi of spring, and after a few track days the tension has dropped back, now it only runs 19 psi off the spring. If you plumb pressure onto the top of the gate also you should be ok either way, mine easily runs a flat 32psi now with the 5 port Mac.
I have a 3 inch dump, and 2 inch off the 45mm gate. As long as they flow well and merge gradually into a 3.5 inch free flowing system you should crack 400kw with it fairly easily. Mine would be making that if I had a manual box...
22 psi, barely falls over any more than half a pound at 7700. Im running e-boost and pressure to both sides of gate respectively
Edited by abr33
Is that no fit in a r32 with a 25 in it stao? What fouled?.
I want to run plumbed in no matter what so can't include screamer. I prefer to hear the engine while its making noises not finding out after when its brokent
Edited by nick81xd
It shouldn't make noises :/
Kurtis ran 500hp with the gate plumbed back and 3inch system....
Mine is a screamer so results are irrelevant I guess.
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
