Carbon Fibre Or Fibre Glass Parts 180Sx,s15,r32,r33,r34,r35,evo
ahah im noob.. read the first post which has prices >_>
Q1, does the rear diffuser come with the side vortex thinggos??
Just put me down for wing blade and exhaust shroud for now though.
Edited by YE34OK
Longz : R34 GTR Nismo Side skirts , Rear pods , Canards, exhaust shroud cooling panel and rear diffuser, EVO side skirts, canards, rear exhaust shroud
haz_jaz : skirts/pods and CF Wing blade for R34 GTR
Terry_GT-R34 : EVO Skirt Add-ons , Radiator Cooling Panel, Rear Boot Spoiler Lip
jase_c : R34 Gtt radiator cooling panel
DeaN20 : R32 GTR radiator cooling panel
Charles89 : R34 GTT CF radiator cooling panel
Sinno: Evo rear diffuser and canards.
Some guy: 350z lip + skirts
joelsy777 : R33 hood bonnet lip.60mm Pillar gauge cover,B Pillar cover, Centre console arm rest
DJRIFT : Carbon mirror cover r34gtt
YE34OK: Carbon wing blade , Diffuser exhaust shroud
gtsttrk:R33 Bee R wing
Coldfusion : R32 headlight intake
tomo : R34 cooling panel, R34 mirror covers
OON80 : R34 GTT canards
Group buy looks good so far ! order should hopefully be put in soon after confirmation with everyone !
for all the people that are thinking of jumping in now is the time !
Missed me off the updated list again.
Thanks for putting up the pic of the mirror covers.
I will have
34 weather sheilds
34 mirror covers
32 lh headlight
Thanks
DJRIFT : Carbon mirror cover r34gtt, R34 weather shields r32 lh headlight < --- updated :action-smiley-069:
Sweet, would I be able to get a pic? I'll add that to my order aswell then.
R34 GTT carbon cooling panel, R34 carbon mirror covers and a R34 GTT carbon boot.
tomo : R34 cooling panel, R34 mirror covers, R34 GTT carbon boot
Did you hear back about the B-pillar covers?
I'm in for an R33 GTR OEM wing blade either way. Let me know about the B-Pillars then I'll decide on them
any pics of this gear? i could be interested in some of the 32 stuff
Thanks
So the pictures posted is not the actual product? Just some found on the web?
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
