nitto stroker kit
nitto oil pump
nitto head gasket
rrr racing block
peterson dry sump
head package through crd, dirt garage or equivalent.
ross or ati balancer
arp studs throughout
adjustable cam gears
hks t51r turbo
id2000 injectors
larger fuel rail
or
RIPS engine package
or, let us know your goals and budget.
will help decide what to do.
Ive so far purchased cp forged pistons,spool rods,acl bearings,arp studs all round,jun oil pump, just need ideas on cam duration/lift and valve springs also what turbo to run with to get the most out the 26.
all good.
id love to be able to afford their gear too.
maybe one day.
maybe not.
theres a thread currently discussing pretty much this.
cant remember exactly where, bit some were saying you can get a racepace engine(yours rebuilt by them)for 10k incl parts and labour.
may be worth freighting it?
do you need turbo setup?
do you need fuel system?
now we know a rough budget, what do you want/need and what power goals are you aiming for?
twins or single?
Be interested in looking into that thread if you happen to come across it.
Im hoping to get enough help through this thread from past experience builds so i know which direction on parts selection i should take on getting good power from a budget.
Am looking at getting rid of the twins and going single so turbo choice also would help.
nitto stroker kit
nitto oil pump
nitto head gasket
rrr racing block
peterson dry sump
hks t51r turbo
id2000 injectors
larger fuel rail
or
RIPS engine package
Jesus creepers Luke! RRR block itself is rare as hens teeth yet alone $10k+ to procure .
be better off just getting N1 block from Just Jap cost like 2.6K.
I was under the impression that Dan was not doing engines and ERD anymore? Health Issues Maybe from what I recall?
Dan is still building engines as a sort of private on the side setup, from what i gather, but ERD itself is no more.
Probably a lot less messing around only doing engines.
  • 2 months later...
    • The incentives are mostly the same, yes. Ethanol is cheap compared to the cost of doing 98-100 RON with crude oil alone. 87 to 93-94 AKI all with E10. In 2020 Canada mandated E10 as a part of their "renewable fuel standard" and is supposedly going to go to E15 in 2030. In California where there are only 8 refineries with two threatening to shut down next year it's been over 20 years now of E10 and 91 AKI maximum because there's just not enough refinery capacity or crude oil supply relative to the demand for premium unleaded fuel. And CARB's low carbon fuel standard means functionally none of the diesel available at the pump is made from crude oil anymore. It's almost all entirely 20% biodiesel blended with 80% renewable diesel (hydrotreated vegetable oil) now. The number of gasoline vehicles that support E15 or higher ethanol concentrations is surprisingly low, I can't imagine it being wise to play tricks like this without flex fuel sensors in most of the fleet.
    • It's almost certainly the same as the one next to it. Have a fish around amongst these hits https://www.google.com/search?q=surface+mount+transistor+m33&sca_esv=9cb49794e0b2005d&source=hp&ei=2vJ5aNjTB7Kw0PEPldnS8QM&iflsig=AOw8s4IAAAAAaHoA6qkfmF6XcygtrZ4Vu9f92NXF_RFd&ved=0ahUKEwjYqIPP7MWOAxUyGDQIHZWsND4Q4dUDCA8&uact=5&oq=surface+mount+transistor+m33&gs_lp=Egdnd3Mtd2l6IhxzdXJmYWNlIG1vdW50IHRyYW5zaXN0b3IgbTMzMgUQIRigATIFECEYoAEyBRAhGKABMgUQIRigAUjKCFAAWABwAHgAkAEAmAHfAaAB3wGqAQMyLTG4AQPIAQD4AQL4AQGYAgGgAuYBmAMAkgcDMi0xoAfMBLIHAzItMbgH5gHCBwMyLTHIBwU&sclient=gws-wiz
    • South Australia, which is hardly as far behind as the rest pf Oz makes out, and who is also not a paragon of progressiveness (read that as over-legislation) in the area of vehicle standards, has this to say on the subject: Adjustable coil-over suspension Aftermarket adjustable coil-over suspension components are suspension units that incorporate an external thread on the main body and corresponding threaded spring saddle that allows the vehicle's suspension height to be varied. If fitting aftermarket or coil-over suspension components you must submit an Application to modify a light motor vehicle form and a report from a light vehicle engineering signatory (LVES).
    • Hi all, Long time since I've posted here. Looking for some advice on what I can remove to further identify the cause of my issues.  I can move the passenger seat forward and back but the knob used to adjust the seat angle is pretty much free spinning, there's very little resistance.  Removing the side cover I can see that the chain is intact but the shaft for the adjustment spins without the gear attached to it moving.  What's my next step for disassembly here? Is this a common fault? Just being a little cautious as I didn't want to start removing bolts for a spring to fly out or something equally as stupid.  Cheers
    • Those above shitboxes, mediocre and above usually have a turbo strapped to them, hence the slightly higher octane is required.
