  • 3 weeks later...
R33 GTR
Nismo 1.2mm metal head gasket
Racepace cam gears, but not yet adjusted
Garrett -9's with 1 bar actuators
Nismo fuel pump (rewired)
Mine's front pipe
3" test pipe
3.5" Tomei Ti Expreme
Greddy Profec B spec 2 (disconnected)
17psi on standard ecu
Soon to be added: PFC, ID1000, Z32 AFM, E85
R31Nismoid claims 280rwkw on 18psi @ Racepace dyno with his stock ecu.
To be honest I was expecting much less though - around 250rwkw.
I would not be surprised if it were to read lower on a dyno dynamics roller dyno.
Point of my dyno check was to ensure AFR is safe, timing is accurate and no knocking - all of which were achieved.
Also I'm very glad to report that there is very minimal boost drop from the Garrett 1 bar actuators with only a small amount of preload wound in.
Reaches a maximum of 17psi at 4,000rpm and does not drop below 16psi all the way till redline.
When it gets tuned, I will get the cam gears dialed in and reattach the boost controller to keep the gates shut for as long as possible.
Looking forward to some good improvements in the response department.
I'm not a doubter because I have no clue about these things but I just haven't seen it before so I was amazed.
Keep up the good work though and as long as the AFR's are sweet and you're happy then that's all that matters
Nah, I'm talking about Grant, cos I know he had his old 33 gtr tuned by Trent and got a little over 300kw on the same dyno with similar mods and he had PFC.
To settle any doubts, I think it seems like quite a normal figure. Although peak power is quite similar, you can see where the gains are with the car properly tuned.
50Nm difference in peak torque. Reaches almost exactly the same spot (Approx 4200rpm)
80kw vs 95kw @ 3000rpm
190kw vs 210kw @ 4000rpm
220kw vs 265kw @ 5000rpm
260kw vs 300kw @ 6000rpm
If Grant doesn't mind I'm happy to post his graph or he can so people have something to compare with.
Or it can be found in the RB26 dyno results thread anyway
Unregistered Dark Blue 34 GTT on way to Vicroads - don't worry, it's registered now.
Congrats! Didn't spot you sorry, maybe I was too busy focusing on make do GPS and rushing to get to Trent's cos was running late
No stress, with that colour, it'd blend right in traffic anyway!
Fatz, he's talking about my first 33r with GT-SS's not the last one.
Michael, post them up, btw I didn't doubt you. Just found it interesting that you achieved with standard ecu.
Probably says about your motor being healthy - I was told mine had low compression in cyl 2, didn't know of it until I enquired about buying motor/box back. No idea how long the cyl 2 were down for, never done a compression test on cars I buy :/
Grant, nothing unhealthy with that figure at all. As you can see, by 5000rpm you're up by a massive 45kw.
Don't think you mentioned cam gears either in that recipe. Obviously some more gains to be had in the mid range.
That along with E85 would have been pretty damn quick setup. Also you didn't have fuel pump, injectors or afms upgraded which would have been the limiting factor to push any further.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
