Hi all,
As hard as it is putting this ad up, the time has come to sell my dream car. Only selling due to leaving my current job & very soon to be moving back to NSW before heading overseas. I need it sold soon, hence the price corresponding with K's & modifications.
$41,500
This is the ultimate street & circuit GTR built with only the best parts available & maintained to the highest standard.
HKS TOMEI NISMO etc no ebay or non-genuine parts have ever been used. The car has had upwards of $85,000 spent on it.
As of 13 May 2013 the car has had another 12months rego put on (valid till 21-5-14) & now a Road worthy Cert ready to go.
The car has modifications plates for: Aftermarket seats, aftermarket breaks, Roll cage (at the end of april this year, you can now NOT get a street car mod plate certified for a cage. But this is already done so its good to go. Its also mod plated & rego'd as a 2 seater.
The car has been freshly tuned only a few weeks ago & made over 500hp at all 4 wheels on a low, safe & very reliable 18psi.
And like it always has, is running like a dream.
All work and tuning is carried out by GT Auto Garage.
As you can see with the road worthy done, rego, mod plates etc this is a hassle free buy.
Serious enquiries only!
NO low ballers or swaps.
Test drive will only be available after deposit is taken.
Don't let this GTR pass you by! Im happy for inspections as this car in the flesh is second to none!
Mods list consists of the following.
3/1995 SERIES 1 BCNR33 GTR V-SPEC
ENGINE
Extensive porting and machining of the head
Modified exhaust ports (enlarged)
Modified intake and throttle bodies (enlarged).
Hks camshafts
Inlet 272deg with 10.5mm lift
Exhaust 280deg with 10.5mm lift
Hks adjustable cam gears
Hks timing belt
Hks valve springs
Hks retainers
1mm oversized Tomei valves
Tomei head gasket
Tomei head studs
Tomei exhaust manifold gasket (steel)
Tomei enlarged throttlebody gasket (steel)
Head flowed and tested
Rocker covers/front timing cover painted Nissan pulsar metalic blue
R34 GTR n1 emblum on centre cover
Nismo oil pump
N1 water pump
Nismo N1 pistons
Nismo N1 rods with 21mm gudgen pins
Standard Bcnr33 GTR crank (wanted to keep it 2.6l)
Nismo bearings, big ends/mains
Nismo sump baffle
Arc oil catch tank
EXHAUST & TURBOS
Brand new Trust/Greedy T-517z 10cm twin turbo kit.
R34 N1 Gtr match ported exhaust manifolds
R34 N1 Gtr match ported dump pipes
HKS stainless Front pipes
HKS Silent Hi-Power 3.5inch stainless exhaust with no cat. (not so silent exhaust)
INTAKE
2x z32 airflow meters
Tomei z32 airflow meter plug adaptors.(Standard airflow meter plugs still attached so wiring harness hasn't been modified)
Apexi twin air intake pods
Hks hpc coated air intake pipes
Hks silicone hoses
Hks clamps polished
DRIVELINE
R33 GTR series 3,5 speed gearbox (freshly rebuilt)
C's short shifter (rare & you cant buy these anymore) The best GTR quick shift on the market.
Brand new Jim Berry race twin plate clutch (sprung centre)
Factory rear V-spec diff.Fluid has been changed and the electronic diff performes at its optimum
Nismo 1 way front lsd
Standard diff gears remain 4.11.
FUEL
Sard 800cc injectors
Nismo larger intake pump
Nismo fuel pressure regulator
COOLING
Hks R34 GTR 105mm intercooler (brand new costs $1757)
Hks hpc coated polished intercooler pipes with Hks silicone hoses & polished clamps
F-win Japanese 3 core 52mm alloy racing radiator (new $1,700)
F-win Japanese radiator air deflector plate
Nismo thermostat
Samco top & bottom radiator hoses
Hks remote oil filter relocator with extended braided lines.
Hks oil cooler.Oil cooler located on passanger side behind the front indicator (on front bar) Screw out the indicator and bracket when circuit racing as it allows more air flow. Modified the wiring to the indicator so it can detach easily.
Also attached a water squirter on the front of the oil cooler so when on track days just give a quick squirt and temps drop down by as much as 10-12deg.
You pull back the wiper stalk and the cold water or ice you place into the water washer bottle squirts a large mist over the oil cooler.Simple but effective!
Also modified the inner guard (plastic) to allow the hot air from the oil cooler to vent out.
INSTURMENTS/ELECTRONICS/ECU
Nismo 320klm dash
Nismo centre gauges
Defi oil preasure gauge (black face)
Defi oil temp gauge (black face)
Defi water temp gauge (black face)
Defi controll box with peak & memory.
Gauges located where the centre ac vents are on the console for ease of vision and keeps it legal.
Hks evc-s boost controller with 2 memory settings.I have the first setting at 1.1bar & the second setting at 1.3bar (about 18psi)
Hks turbo timer
Apexi power fc with hand controller
Split fire coilpacks
Hks racing spark plugs
Brand new factory nissan injector harness
SUSPENSION/WHEELS/TYRES
Hks hypermax PRO circuit coilovers,height & damper adjustable.I have had these re-valved and softer springs fitted for our roads & tracks as the Jap settings are way to hard.
Cusco adjustable upper controll arms
Cusco adjustable front caster arms
Cusco adjustable rear camber arms
Cusco adjustable rear tow arms
Cusco front strut brace
Cusco rear strut brace
Moonface (japanese) sub frame bushes
Moonface diff mounts
Hks Kansi under body bracing
Nismo circuit link sway bars front & rear
Wheel allignment settings are-3.5deg front camber,7deg front castor,2deg camber on the rear,zero toe on rear.
Wheels were Volk TE37s but is being sold as is with GR6's, 18x10 +15
Tyres are new Toyo Proxes T1R 275x35x18 (can fit 295x35x18 for track days)
BODY
Genuine Top secret carbon time attack bonnet (painted white) ($2800)
Aero catch bonnet pins (folding flush type)
Carbon ganador mirrors ($690) **** these are currently on order and have just arrived, just have to go pick them up and pay for them.
Nismo clear side indicators
Nismo 400r clear front indicators
Nismo carbon piller garnish
Nismo carbon rear wing end caps
Nismo factory option rear spats
Series 3 GTR front N1 bar with nismo intercooler ducts
Series 3 GTR front lip (35mm lower than series 1-2) costs $1420
Series 3 GTR xennon headlights with optional xennon high beam very rare and cost me $3600 from nissan Japan
Auto select genuine carbon front canards
Eurou aero parts production front under defuser (Japanese)
Custom made brake ducts (alloy with black powdercoating) drops temps down by 15deg
Empier Aero Top secret carbon fibre rear diffuser
Carbon fibre GTR wing blade
BRAKES
R33 GTR Brembos front and rear
Project MU 2 piece slotted rotors (front)
Project mu club racer pads rated to 800deg (front)
Project MU rear slotted rotors
Project MU break shims
ferodo ds 2500 rear brake pads rated to 700deg
Adr approved braided brake lines front and rear
INTERIOR
Standard front & rear door cards (immaculate condition)
Recaro limited edition SR7 front seats
Nardi deep corn suede 360mm steering wheel
Pioneer stereo fitted
Aircondition system still fitted
ITEMS I HAVE REMOVED FOR WEIGHT SAVING
Rear parcel shelf
Rear speakers
Rear wiper & wiper motor
Boot carpet
Rear seats
Some sound deading. (saved around 25kg).
I have these parts in a box if you wish to re fit them.
Only HKS synthetic oils have been used.
The car is in imaculate condition and there are no loose ends with it, everything works like it should!.
I dont want to sell it and had planned to keep it for life but my personal circumstances have changed very quickly and im leaving my job (currently in the Army) and moving back to Newcastle NSW where ill be there for a short time before i venture off overseas.
there is no money owing on this car and all that needs to be done is drive it.
Its never been driven in the rain by or previous owner.
Only driven once in a blue moon and even then, only to keep cob webs out.
Countless hours have been spent modifying it and all the parts were new and only Japanese and genuine parts were used.
If genuinely interested,
Please contact me (dan) on 0423544543
I'm sure I've left a bunch of things out.
But I can assure you, you will not find a better presented R33GTR v-spec in such good condition.
For pics please go to my carsales:
http://www.carsales.com.au/private/details/NISSAN-SKYLINE-14829066
https://www.sau.com.au/forums/topic/426141-for-sale-r33gtr-v-spec/
was trolling around CarSales the other day and noticed this - and wow indeed.. this is definitely one of the best looking R33 GTR's i've ever seen with the mod list to match it.. good luck with the sale dude i was actually going to request to see your contact details and text you to compliment but i thought nah i won't be annoying haha..
Thanks guys, much appreciated!
I kinda need some help getting the word out there to sell it, as I only have until mid July to see her off.
The car is absolutely flawless and there are no loose ends with it at all. Mechanically it's perfect and is actually really nice to drive!
I know the sale price is in the 34gtr range and even so I feel as tho I should have a much larger ticket on it, not to regain losses as this sale is not due to money issues but due to the quality and stunning condition it's in and the fact that ya just don't see 33's like this. And if I had more time to have it up for sale, there would be another 5-10g on top of it now, so this really is a bargain and rare deal.. It really is like no other 33 out there and I'm at the stage where its not getting driven like it wants to be and I'm to scared to take it out in fear of someone on something happening to it, even stone chips are something I don't wanna see on it haha
I really want it to go to an enthusiast where the new owner can really appreciate and respect how well preserved and tastefully mod'd it is and the time and attention to detail with each modification but also drive it and get it out there as its very sheltered and pampered at the moment.
If u guys could share or just spread the word amoungst friends and other enthusiasts, I'd be forever greatful knowing that the car is going to a good home. In which case I'd happily do an even better deal for someone who won't run it into the ground! :)
I'm more than happy for inspections even if you're slightly interested :)
But since having it for sale, I've had that many dreamers and flat out time wasters that I don't wish it upon any foe let alone u guys when it comes time to sell your beasts! Haha
Thanks again for the kind words :)
Dan
Also included the car has just been window tinted (20% tint and with anti-glare) about 2months ago with a life time warranty, 1kg fire extinguisher, standard mirrors & wing blade that will also come with sale, genuine nismo gear knob, D1 Spec wheel nuts, space saver wheel, brand new battery.
There's most likely a lot of other things I've forgotten too.
Someone get on this! You'll only make money on it!
WoW thumbs up for a stunning and well built BCNR33.
Seen this in the flesh and its a very pretty monsta!
This ran low 58's around lakeside on street tyres,driven by its previous owner.
One very quick GTR
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
    • Dang, those BBS are so nice!
