Just a quick note on Cruise Control installs.
I've had an electric cruise control in the stagea for about 7 years now, and it has been excellent. However, when I changed to the forward facing plenum and moved the throttle I didn't bother hooking it back up again.
Now I'm driving the stag to Canberra each week I decided I needed the cruise hooked up again, so I called the guy who installed it on the number from his old card. Surprisingly, I got the same bloke, Nigel, and he was happy to come out and fix it (nice and cheap too).
So this is just a quick recommendation....if you are thinking about getting cruise control installed (or didn't know you even could), give Nigel at Cruise Control Specialists a bell. His number is zeo four 18 116 404. An electric cruise system will set you back $780 for dash mounted or $850 for stalk mounted like I have.
Nigel was professional, courteous, tidy and careful with the install, and the repair he did for me was cheaper than estimated. Can't ask for more than that :)
The control unit is the black box mounted neatly out of the way in the corner of the engine bay. Cable runs to the throttle body
https://www.sau.com.au/forums/topic/426168-want-cruise-control/
yeah i need this for my r34 and s14, its probably the biggest thing I miss from my old car.
and got my first speeding fine ever a couple of months ago driving to melb, where i would normally have set cruise control
  • 4 weeks later...
Ah the ol' cruise control! Couldn't live with out it! And I'm doing the same sort of kays as Duncan is and I can't count the number of times it has saved my license (And no, I'm not illiterate you smart asses!)
Will see how my new R33 goes on the drives to Canberra and may have to give ol' Nigel a call.
  • 4 weeks later...
  • 3 weeks later...
Im getting a unit installed in the 34 next week, but getting someone local as I cant really get to Sydney to get it done, will see how they go. They did a great job with my car alarm a while back so I trust them to not screw it up
Got it installed, going to test it on the weekend
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
