  • Replies 269
Hi all,
I have received all the parts i need to make another batch today, and will start taking orders. If you would like one, pls contact me with your contact details.
If you would like more info, reply here!
Impakt
Couple more questions, thought this'd be a better spot for it, share the info. and avoid clogging your PM inbox Impakt.
1. What are physical dimensions of the screen?
2. How difficult would it be, for some one with moderate skills, to solder a ribbon cable between the box and screen (say ~30cm length)?
2a. Would the above detrimentally effect the units operation?
The above comes about from the desire to mount the screen in a small space necessitating it's detachment from the box.
3. What's the feasibility of having the display all come up backwards, mirrored, so it could be placed on the dash and used as a Heads-Up-Display?
A switch to choose between Normal/Mirror would be IDEAL!
4. How would, or could, you go about dicking with the speed signal? I ask because i have an auto diff (4.3:1) in a manual car (normally 4.11:1 diff) so my speedo is out, this way i could have an accurate reading.
Good questions Oosh,
1. The physical dimensions of the screen (PCB) is 98mmx60mmx~15mm. THe actual LCD part is smaller.
2. To remotely mount the LCD is not that hard, as long as you know what you are doing. Im happy to sell a display with the LCD and case seperate, so you can mount as you wish. Its 12 wires between the LCD and PCB, so a decent ribbon cable should do the trick. I would recommend you letting me know if you want to remote mount the LCD, that way i wont solder it on in the first place (and create extra work for you).
2a. Won't affect operation at all, just shield the ribbon cable to reduce noise.
3. A super bright VFD or LED module could be used for HUD. LCD will never be bright enough to be used as a HUD.
4. Not possible without re-programming the device, which im happy to do (at a small cost). Just tell me how much you need it tweaked by, and i'll write the code to do it.
Impakt
snip .... /snip
Impakt
Thanks for your answers, if you COULD leave my LCD unattached, i think i will give this a go but please include the wires you would use just in case i decide to go back to stock.
As for speed, it'd need to be altered by a factor of 0.95, i.e. display 95kmh when it's detecting it as 100kmh.
Some further questions:
1. Just how small a fee? :thumbsup:
2. Could i keep the original speed variable? i.e. have a Speed1 and Speed2 var.
3. Will either option (modified or 2 vars) effect compatibility with any of the softwares esp. data loggers?
Cheers.
Found this case at Prime Electronics here in Bridbane.
Did a quick transplant and used some smaller push buttons. Guess I just can't help dicking around with things...
is that a laptop hard drive caddy?
    • I know why it happened and I’m embarrassed to say but I was testing the polarity of one of the led bulb to see which side was positive with a 12v battery and that’s when it decided to fry hoping I didn’t damage anything else
    • I came here to note that is a zener diode too base on the info there. Based on that, I'd also be suspicious that replacing it, and it's likely to do the same. A lot of use cases will see it used as either voltage protection, or to create a cheap but relatively stable fixed voltage supply. That would mean it has seen more voltage than it should, and has gone into voltage melt down. If there is something else in the circuit dumping out higher than it should voltages, that needs to be found too. It's quite likely they're trying to use the Zener to limit the voltage that is hitting through to the transistor beside it, so what ever goes to the zener is likely a signal, and they're using the transistor in that circuit to amplify it. Especially as it seems they've also got a capacitor across the zener. Looks like there is meant to be something "noisy" to that zener, and what ever it was, had a melt down. Looking at that picture, it also looks like there's some solder joints that really need redoing, and it might be worth having the whole board properly inspected.  Unfortunately, without being able to stick a multimeter on it, and start tracing it all out, I'm pretty much at a loss now to help. I don't even believe I have a climate control board from an R33 around here to pull apart and see if any of the circuit appears similar to give some ideas.
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
