  • Replies 269
Hi all,
I have received all the parts i need to make another batch today, and will start taking orders. If you would like one, pls contact me with your contact details.
If you would like more info, reply here!
Impakt
Couple more questions, thought this'd be a better spot for it, share the info. and avoid clogging your PM inbox Impakt.
1. What are physical dimensions of the screen?
2. How difficult would it be, for some one with moderate skills, to solder a ribbon cable between the box and screen (say ~30cm length)?
2a. Would the above detrimentally effect the units operation?
The above comes about from the desire to mount the screen in a small space necessitating it's detachment from the box.
3. What's the feasibility of having the display all come up backwards, mirrored, so it could be placed on the dash and used as a Heads-Up-Display?
A switch to choose between Normal/Mirror would be IDEAL!
4. How would, or could, you go about dicking with the speed signal? I ask because i have an auto diff (4.3:1) in a manual car (normally 4.11:1 diff) so my speedo is out, this way i could have an accurate reading.
Good questions Oosh,
1. The physical dimensions of the screen (PCB) is 98mmx60mmx~15mm. THe actual LCD part is smaller.
2. To remotely mount the LCD is not that hard, as long as you know what you are doing. Im happy to sell a display with the LCD and case seperate, so you can mount as you wish. Its 12 wires between the LCD and PCB, so a decent ribbon cable should do the trick. I would recommend you letting me know if you want to remote mount the LCD, that way i wont solder it on in the first place (and create extra work for you).
2a. Won't affect operation at all, just shield the ribbon cable to reduce noise.
3. A super bright VFD or LED module could be used for HUD. LCD will never be bright enough to be used as a HUD.
4. Not possible without re-programming the device, which im happy to do (at a small cost). Just tell me how much you need it tweaked by, and i'll write the code to do it.
Impakt
snip .... /snip
Impakt
Thanks for your answers, if you COULD leave my LCD unattached, i think i will give this a go but please include the wires you would use just in case i decide to go back to stock.
As for speed, it'd need to be altered by a factor of 0.95, i.e. display 95kmh when it's detecting it as 100kmh.
Some further questions:
1. Just how small a fee? :thumbsup:
2. Could i keep the original speed variable? i.e. have a Speed1 and Speed2 var.
3. Will either option (modified or 2 vars) effect compatibility with any of the softwares esp. data loggers?
Cheers.
Found this case at Prime Electronics here in Bridbane.
Did a quick transplant and used some smaller push buttons. Guess I just can't help dicking around with things...
is that a laptop hard drive caddy?
    • So, if the headlights' cutoff behaviour (angles, heights, etc) are not as per 6.2.6.1.1 without automatic levelling, then you have to have to have automatic** levelling. Also, if the headlight does not have the required markings, then neither automatic nor manual adjusters are going to be acceptable. That's because the base headlight itself does not meet the minimum requirement (which is the marking). ** with the option of manual levelling, if the headlight otherwise meets the same requirements as for the automatic case AND can be set to the "base" alignment at the headlight itself. So that's an additional requirement for the manual case. So, provided that the marking is on the headlight and there is a local manual adjustment back to "base" on the headlight, then yes, you could argue that they are code compliant. But if you are missing any single one of these things, then they are not. And unlike certain other standards that I work with, there does not seem to be scope to prepare a "fitness for purpose" report. Well, I guess there actually is. You might engage an automotive engineer to write a report stating that the lights meet the performance requirements of the standard even if they are missing, for example, the markings.
    • Vertical orientation   6.2.6.1.1. The initial downward inclination of the cut off of the dipped-beam to be set in the unladen vehicle state with one person in the driver's seat shall be specified within an accuracy of 0.1 per cent by the manufacturer and indicated in a clearly legible and indelible manner on each vehicle close to either headlamp or the manufacturer's plate by the symbol shown in Annex 7.   The value of this indicated downward inclination shall be defined in accordance with paragraph 6.2.6.1.2.   6.2.6.1.2. Depending on the mounting height in metres (h) of the lower edge of the apparent surface in the direction of the reference axis of the dipped beam headlamp, measured on the unladen vehicles, the vertical inclination of the cut off of the dipped- beam shall, under all the static conditions of Annex 5, remain between the following limits and the initial aiming shall have the following values:   h < 0.8   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   0.8 < h < 1.0   Limits: between 0.5 per cent and 2.5 per cent   Initial aiming: between 1.0 per cent and 1.5 per cent   Or, at the discretion of the manufacturer,   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The application for the vehicle type approval shall, in this case, contain information as to which of the two alternatives is to be used.   h > 1.0   Limits: between 1.0 per cent and 3.0 per cent   Initial aiming: between 1.5 per cent and 2.0 per cent   The above limits and the initial aiming values are summarized in the diagram below.   For category N3G (off-road) vehicles where the headlamps exceed a height of 1,200 mm, the limits for the vertical inclination of the cut-off shall be between: -1.5 per cent and -3.5 per cent.   The initial aim shall be set between: -2 per cent and -2.5 per cent.
