  • Replies 269
hey guys,
i'm just curious as to how you all have mounted yours?
I'm thinking putting it just to the left of the steering wheel on a r32.. but how to attach?
any ideas/pics?
  • 1 month later...
do u know or heard if these work on the A31 cefiro's?
i just had a quick look and can't seem to find the consult plug, dunno if it was just me, but any other ceffy owners found the consult plug in there car?
on the other hand has anyone had hard wired it in manually?
Does the big screen allow more items to be displayed? And how much extra for it? And how much extra from the different lcds (you mentioned something about same as safc somewhere in the thread)?
Thanks
The big screen has the same number of characters as the smaller one, it's just bigger. It therefore shows the same number of parameters to be displayed.
The bigger LCD if you're interested would cost an extra $100, this would cover the screen and front panel. Everything else is the same.
Different LCDs (like the ones the S-AFC uses) are an extra $120 on their own from memory, this is from the manufacturer (whose name escapes me atm).
Impakt
  • 1 month later...
  • 2 months later...
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
