Great write up mate. Spent my Sunday morning reading thru it. Was wondering if you have done any brake ducting (how and pics?) and where you got the passenger side head light carbon duct from?
Thanks Adam, stay tuned as there's heaps to come. There hasn't been any need for brake ducting as yet, our last track day and prior to that the brakes were fantasic, now that we have blocked up the holes in the front bar and with more track laps it could be a different story. If needed one way would be to create holes in the front bar, attach silicone ducting to it and guide it to the caliper. Ill post pics up if needed. Only the drivers side is carbon, the left one is fibre glass from tomei. Justin from Revzone.com.au ordered most of my jap parts as he always gets awesome prices. Here's a link of what it looks like below.
http://www.nengun.com/tomei/headlamp-air-intake-nissan-skyline-r32-gtr
motor looking pretty shmicko!.. on the topic of brake ducting, I am/was planning to mount some allstar brake ducts into my 400r style bar, 3" hose back to ally air guide plates mounted to castor rods/LCA's BUT... how did you go with 3-4 laps? i'm thinking for sprints time attacks and short style events, brake ducting Vs blocked holes for greater aero benifits, whats the verdict?
For sprints and time attack as they are usually under 6 laps its never been a problem, I've run alloy air guides in the past but took them off. I physically couldn't tell the difference between them being on or off. Not sure what the temps were at but it has not affected the braking what so ever as the brakes are fantastic. So now with the front blocked off it may be a different story, Bc don't think it will make any difference as time attack is only a few laps at a time. Recently read an article by Simon mcbeath in race car engineering, the short story.... They tested a wrx with a small front splitter and a larger front splitter in a wind tunnel test. Test showed there wasn't much downforce difference to the front of the car with the larger splitter vs the smaller splitter which is odd, they then blocked off all the front holes in the front bar and all the front down force then appeared. Seems previously not only was the open bar causing drag but the air was escaping through the bar and then under the car not allowing the downforce to occur.
ahh okay, yep, read something similar on time attack forums or somewhere ages ago. seems as tho brake ducting offers no gain for 6 laps or less. that settles that then :cheers:
It varies for all, depends on your driving style, brakes, weight of car, track. If you notice you need cooling its not that difficult to do later.
Speaking of brakes though... My rotor hats were just modified to suit v8 supercar rotors which arrived today.
  • Like 1
How long till engine is in and running?
Great question, car was supposed to be ready in July but had some unforeseen hold ups. So this time I don't wont to state exactly so I don't disappoint myself lol. There's heaps still needing to be done and guys can only work after hours at the moment. I'm gonna say completed by September. Ill post the vids up when its alive and tuned if I get a chance.
We are happy to welcome a new sponsor onboard, VPW Australia. We now have all our proflow fittings, hoses, alloy bends and clampshell couplings to put it all together. There catalogue is a novel, they stock everything.
Looks great Steve.
However, I would have thought that mounting the oil tank at the front like that would leave it subject to possible damage.
I would have thought mounting it in the boot would have been better in the the case of an impact, and even with weight distributuion.
Looks great Steve.
Hey Damian, its only subject to damage if you stack the car, placing it there gives us better weight distribution in the front left as Phillip island has mainly left hand turns. Also by placing it there it needs much less plumbing which saves weight and the biggest bonus is that it costs less in plumbing too...score!
This is true. But shit does sometimes happen. Fingers crossed it doesnt lol.
Yeah i know how easily plumbing can add up, especially when it runs the length of the car a couple of times over.
Ive never personally driven PI, but i can see where you are coming from. I was more thinking about the front and rear distribution, rather than left and right. But I dare say you'd have more experience in this than me haha.
Good luck man. Would love to see this thing screaming in the metal.
  • Like 1
    • Brooooo Please send ABS control unit schematic Please! R33 gts25t ABS (Its two plug ecu, black and white) wire colors possible? [email protected]
    • Don't even try to run it on the stock ECU if you're going to have the boost controller bring boost above ~10 psi. I've already told you that. If you use the Nistune ECU, you will need to CAREFULLY read the available documentation for Neo tuning, and read some threads on the Nistune forums, to discover the various things you have to do to prevent the ECU from going bananas when the boost is too high. The is a table associated with th boost sensor that must be modified to prevent it from shitting the bed. This is just one of the things that you will need to do to the tune in Nistune, because the Neo turbo ECU will be expecting to see a number of things (such as the TCS) that are not there, and you have to block the DTCs on those. It is totally not surprising to me that you are having the problems that you are, but the solutions to these problems have been known for >15 years. So just get it done.
    • Hi. Sry iam not a mechanic and iam not at the car atm so i dont know 100% but they told they measure those and even try to change those. AFM they have two. Coils are new a they have my old one too. Plugs too. ECU...we have 25 NEO stock and Nistune 25 NEO.   But i dont know if any one those could be the problem and why/if/what can cause this, Only thing they did not check is fuel...but that walbro 255 is new(like 1,5 years)... That fuel pressure gauge idk...but i let them know Any suggestions?   EDIT: how can they know if it is like you say he ECU pull power when it reaches a specific boost level that is too high? Tha car has boost controler
    • Can you clarify what you mean by boost cut, do you mean it misfires both when under load (driving) and when stationary and out of gear? Or does the ECU pull power when it reaches a specific boost level that is too high (boost control issue)? Does it occur at idle with no throttle? When you say "the ECU is OK", what ECU is it and why do you think it is OK? Have you used the NEO ECU, and if so do you have a MAP sensor attached? Same for the AFM, why do you think it is OK? Do you have any way to put a fuel pressure gauge on it (even just a mechanical one between the fuel filter and fuel rail)?
