As above D2R, if you go to Autobarn for replacements - take a toilet with you. I almost crapped myself when he said $350
EACH!!!
Needless to say i bought Philips Patent licensed ones that are 6000k off Ebay for $80 delivered.
Very clean white light with a tinge of blue.
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6876730
EACH!!!
Wt! $350 / ea...........
when did you buy it?
I just saw on ebay selling $30 now.
I am looking for 8000k
One more Question....when i change the HID
do i need to take off the bumper???
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6876776
No you don't need to take off the bumper. It's all done at the back of the Headlight. I was even able to do the drivers side without removing the battery.
You rotate the white/cream coloured cap with the little tab hanging off it clockwise to remove the cap.
Then you will see the metal cover that needs to be unclipped from its mounts.
From there you can rotate the main plug to remove it from the globe
Then you can undo the clip that holds the globe inplace and remove the globe itself.
I am pretty sure that procedure is correct as i did it about 3months ago.
Make sure you don't get your fingers on the new globe when installing.
Edit : These are what i bought
http://www.ebay.com.au/itm/Philips-D2S-D2R-D2C-Xenon-Bulbs-6000K-35W-Maxima-02-07-/250689991471?pt=AU_Car_Parts_Accessories&hash=item3a5e49b32f
He will then msg you back to specify which exact bulb and you say Dee Too Arrr :D
Edited by Jezboosted
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6876794
Thanks mate good info, just bought myself a set after reading your post :thumbsup:
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6877987
I found the c34 headlights better than most new cars. What makes HIDs so much better?
HID lamps are a whiter light. they also use less power for the amount of light they produce. the lamps in the Stagea, are 35w the H1's they put in for complience are at least 60w lamps.
  • Like 1
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6877997
But I saw it dont hv much room bw the battery and headlight.
However, on the top of headligh witten H1, so I sould but H1 or D2R??
My stagea all is factory.
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6878191
Awesome ! Glad to help.
I just remembered another thing - you will notice that the globe base has little cut outs in it or "locators". Make sure these are lined up so the bulb goes back in nice and flat.
Play around trial fitting the old ones first so you get comfortable with the procedure. I don't like forcing new parts :D
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6878193
H1 is the parker bulb ( look at link it's tiny )
https://www.google.com.au/search?gs_rn=15&gs_ri=psy-ab&tok=CYvfPD0ZJyTFJX8Lf2v8OQ&suggest=p&cp=5&gs_id=k&xhr=t&q=h1+bulb&safe=off&bav=on.2,or.r_cp.r_qf.&bvm=bv.47244034,d.aGc&biw=1680&bih=902&wrapid=tljp137035021636508&um=1&ie=UTF-8&hl=en&tbm=isch&source=og&sa=N&tab=wi&ei=ZuKtUb--Cs-5iAfe64DIBA
I didn't even need to look when doing the battery side, did it by feel while squishing my hand in there :D
Anyways, worst comes to worst - remove battery :D
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6878198
I did remove the battery to change the small headlight last week. :no:
and i saw the lump shound hv some screw locked, right?
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6878219
  • 1 month later...
same as R34, there is a small odd headed screw holding them in, i never put these back as they do almost nothing and the base clips itself in.
phillips is the way to go. 6000k give a better whiter light in my oppinion.
https://www.sau.com.au/forums/topic/426346-c34-stagea-hid/#findComment-6952085
    • Given you're running a 2.8 and my 2.5 is not really like for like, I suspect there could be a bit more timing you could give it. What is the kW yield per degree you're putting through it? Here's my E85 map to give you an idea, where it was I could still get another 3~4kW per degree thrown at it.
    • It turns out that Setrab make a fan specifically for the oil cooler which is great and I've installed it with minimal swearing. I removed my 2x 12in push fans from the front of my aircon condenser and wired them into this. My main thermo fans kick on when I use the aircon anyway and would effectively already be working as puller fans through the condensor which is infront of the rad. The push fans (understandably) didn't really do much in the config they were previously in so now they're out. Now we're on to the "Oil fan doesn't really do much either!". Yes I'll duct it next if it does nothing in heavy use which it shouldn't. But hey, the object exists and fits great and is cool. Let me have this. The car is still in the "do my fittings leak oil now? do my wheels actually rub?" phase. I did a spirited drive on them and didn't hear or feel anything. Then I got back home and noticed there were grind marks on the inside of the rims, though I couldn't see where they were touching I got out the grinder and attacked the suspects. Note: I do not know how to use a grinder. Then I realised I had dragged my new rims across my concrete driveway before I did this drive. I didn't think I had damage at that time when I briefly looked...... but remembered this occurred after I did all the angle grinding. The grinding on the wheels in some very specific spots. It's not around the whole rim for example, which lines up with dragging it across concrete more than hitting a suspension component for even 1 full rotation. So everything is currently painted and taped up and I need to test it some more to see if it really IS rubbing, but from inside the car it doesn't feel like it is. In other news I attempted to do a before and after comparison of the heads/cam upgrade thing. Dynos lie, everything is in different measurements. Here is the data from the sandown back straight. Car go faster than before. Vroom vroom.
    • Here's my base ignition. +3 correction to redline when shooting water/meth which is always on. Looking at my old ignition table, I should be able to add 1-2 degree's next time I'm on the dyno.  Let me know your thoughts.
    • Given what I know now - same haha, but this was 12 years ago with second hand 740cc Nismo injectors in my S15 daily, I was too busy hunting elsewhere for the issue to even look at the injectors, running through some cleaner was a happy coincidence haha
    • Not a terrible idea. But if I ever had concerns that my injectors were sufficiently dirty to be causing me a problem, they would be out of the engine and onto the actual injector cleaner/testing bench.
