Yeap. I'm just looking at coilpacks, fuel pump and maybe a short shift kit too. Just reading on the forums at the moment for some more information and recommendations.
Plenty of info on here, if you get stuck just ask one of us and we will be happy to help....
Splitfire coilpacks are tried and tested, fuel pump choice depends on your goals etc and as for the shifter kit, i have the Nismo but i dont believe its much shorter..... Good shift feel tho :)
Oh, if you want to join SAU NSW too, there is some info in this thread -
http://www.skylinesaustralia.com/forums/topic/365434-s-a-u-n-s-w-club-membership-faq/
Its pretty handy if you plan to do any events or want access to the NSW members section :D
I just wanted to mention a side note that occurred while I was installing the intercooler. The kit was not designed with a nipple for a hose on the pipe going into the I.p. So I bought a threading kit and threaded a brass nozzle onto it. I bought the nozzle from autobarn. It looks like this
Some people say it's a power steering sensor something. I'm not too sure what it's for.
Edited by Therealsandybang
  • 3 weeks later...
So. Alot has happened since the last time I posted.
This came out of my radiator. It looks like they used tap water in the coolant when. They were in Japan. After spending hours flushing and reflushing the radiator I got rid of the gunk.
I opted not to use radiator flush. As I didn't want larger pieces to break off and get stuck in my core all at once. Instead I refilled the radiator with water. Ran the car with high heat and aircon on and drained and flushed the fluid with hot water. It worked a treat.
I used nulon llc as it is very close to nissan llc spec. I used a 50/50 llc to distilled water ratio.
Everything is looking nice and new and running well
I got a chance to use a hoist if I helped with an intercooler install for a Rex
I must say it was easy compared to my install no cutting of re bar or chassis required.
He used the autobahn 88 kit. A decent kit for the money but the core was heavy as hell
My radiator flush was done at 80000km
So just had injectors replaced with cleaner better flowing stock items. Spark plugs replaced with iridiums. It took a fair while to remove everything carefully and do it. post-101240-13760080563215_thumb.jpg engine bay as of now.
New wiper modules. They are 35 a piece but they work really wellpost-101240-13760080394241_thumb.jpg new item on left
Sandwich plate for oil temp finally inpost-101240-13760080289188_thumb.jpg it's the red thing
I'm following along too :thumbsup:
Just a word of advice; keep an eye on that oil sandwich plate for the first few days. They have a nasty tendency to develop leaks. Just keep an eye on it and sort out any issues if it gives any.
Yeah man. It's the second one I've been through. The first one was purchased from a reputable Japanese Aftermarket parts company here in Sydney. The sandwich plate I got from them didn't work out of the box. I never went back there because their customer service was abysmal. I was actually really disappointed in them because I heard good things. Anyway this new one has held up so I'm praying it works.
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
