Okay so even though this is a fairly straight forward job. I'll post a how to any way. This is how you install a nismo fuel pump.
Before you do anything please make sure your battery is disconnected your fuel lid open and you have at the most a quarter tank of fuel.
Your pump access is located on the rear right side under your parcel shelf in the boot. It is covered by a panel with screws
Undo screws disconnect all sensor clips and make sure you have plenty of rags handy or a oil tray to collect fuel from fuel lines.
To get the black cap off use a plastic screwdriver and a rubber mallet to turn it anti clockwise. Use 5/10 force. Make sure you make a rough mark as to where the black cap started. There is an arrow on the white plastic that shows where the mark needs to be tightened to
Remove cap. Pry open plastic cover and remove rubber lining. Remove hose connections underneath cover
To remove fuel pump. Gently pull up. It is located just behind right rear passenger seat against the wall. It is not bolted on. It uses a hook latch system
Here is a comparison. The stock pump on the right is actually closer to the camera making it appear larger but it is in fact tiny compared to the Nismo.
The Nismo bracket clicks into the existing plastic housing. Feed the filter element in first making sure it makes its way lower and deeper into the fuel tank.
It will take you a few tries to mount the Nismo. Make sure it has clicked into the plastic bracket and that you haven't just fit it in between the bracket and the wall of the car. The pump should sit straight and not move.
Connect all hoses and mountings. Change fuel filter. Re attach battery. Place car on On then start vehicle.
  • Like 1
After driving along all day you can just hear the pleasant whirring of the Nismo pump. It is in no way loud or audible inside the cabin. Highly recommended. Fuel pump and filter was done at 81000kms
Um good question. At this level of modifying i didn't feel the need to. The pump itself was a sizeable upgrade to stock. You can do it if you want to im sure you would get a higher voltage/efficiency.
Makes sense. Thinking about doing similar mods - currently in planning phase :)
Keep 'em coming.
  • Like 1
I believe the Nismo pump is designed to run with the lower voltage that the pump speed controller supplies them with. The issue with aftermarket pumps like Bosch and Walbro is they are designed to work at 14v and they struggle with lower voltage.
So Yeh, shouldn't need to rewire for the Nismo.
  • Like 2
Yeah mine has a mind of its own. After the pump, injector, fuel filter and spark replacement my car seems to be running better and it does feel like it pulls a bit better. But it's ducking fuel like no tomorrow. I'm desperately in need of a tune.
Nice build mate. Red is the fastest colour besides blue ;) That 200kw mark the neo will S$%T it in. My 33 just had the turbo hi flowed and a 355kw AEM fuel pump put in. On stock ECU, Injectors, with 3 inch exhaust and 10psi made 195kw @ the wheels :) and 98BP ultimate fuel :P Oh and she has 200,000km so with those mods your looking at my mate had a similar in his GTT and made 235ish :)
Keep up the good work.
  • Like 1
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
