This is my r31 skyline, bought it when I was about 15 years old off the r31 skyline club.
Got involved in the whole r31 "scene" and got my mum to take me on car crews as many weekends in a row as possible.
As you can see the car is a series 3 silo, with an rb30 with minor mods such as-
Auto spoiler, projectors, exhaust, neat little intake setup, pedders struts spings, whiteline swaybars and nolathane bushes throughout.
Some of you may know that this was ED's car, ed was/is a perfectionist and sold me the car in awesome condition.
Was an awesome little buy that's for sure!
So I attended my first ever track day at skyline nationals 2010 in Adelaide which happened to work out perfectly for me as I was moving to good old Roxby downs to work in the mines at exactly the same time (originally from wellington NSW)
So I did the trip all in one go, moved house and attended the skyline nationals, still not having my p's at the age of 17 meant I dragged mum along aswell.
Was a good learning experience, anyway, moved out of home to SA to work in the mines, got my p's got some money together and decided to spend some of it-
coilovers- 6kg rear 8kg front Angry industries U-weld coilovers
Wheels- 18" work eurolines
spacers for the front,
import brakes (struts foul on gts1 wheels without spacers)
HEL braided brake lines
and adjustable castor rods
Junk Garage Parts supplied me a new FRP vented bonnet
Looked quite good in my opinion, was loving it, but something was still missing.....
ENGINE BUILD OVERVIEW- not including all parts/modifications
Nitto high volume rb oil pump
Nitto h-beam connecting rods
Nitto crank collar
Nitto high compression custom pistons- These are a top of the line custom piston to suit a big RB30 NA engine build using an RB26 head being undertaken by Nitto South Australian Dealer Garage 7. Piston features are: 12:1 static compression ratio, asymmetric style forging, under crown milling, skirt window milling, under side oil shed coating, tuff skirt coating, thermal barrier crown coating, custom valve relief cut, contact reduction grooves, accumulator groove, custom select pins and rings.
ACL Race bearings - mains / connecting rods
ACL Race ProSeal engine gasket kit
Brian crower 1mm oversize valves
Ross metal jacket balancer with cam / crank trigger kit
N1 water pump
Nismo low temp thermostat
Oil restrictors
Camtech RB26 camshafts- Camtech RB26 431A grind, Duration - 280 ADV IN / EX. Valve Lift - 10.8mm IN / EX
Camtech valve springs and titanium retainer kit
Custom made ITB setup
XSpurt injectors
Heavily ported cylinder head
Link G4 Storm ECU
Genuine Nissan front / rear seals, idler and tensioner
Custom Gates belt
IGN-1A race coils
Ill think of the rest eventually lol
Edited by Wayne.
Awesome, loving it. Should sound nice too. Did a 31 with a mate a couple of years back, was mainly a panel and paint project but made 109kw with very basic mods, was stacks of fun but would of been 10 times better with a engine like yours in it! Good work.
Awesome engine build!
My R32 started out life with the RB25DE engine... I loved the sound and throttle response. I was very tempted to swap the bottom end for the RB30, but went down the boring (and more cost effective route) of an engine swap to a RB25DET.
Will be very interested to see how you get on.
So ive had a bit of progress on the intake side of things, the filters will be getting trimmed down, I also have another piece that bolts on to make it like forward facing plenum to run a pod filter.
Very very cool, very cool. Engine is looking badass. Should sound fantastic too. I would guess 140-150 on 98? Judging by a mates basic 30 with cheapie eBay chip and very basic mods and mild cam. Twin cam 12:1 with better ecu and better everything else should see mid 150's I would think? E85 who knows. Shouldn't be too far off your expectations!
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
