Thanks, I think the build is pretty much finished, as far as I want to go with it anyway.. Actually considering selling the car and moving onto a different beast cause of work change and it mostly sits in the garage, may as well have a ute that can be used everyday... :/
No!! :domokun:
Been following this thread for a while and saw the car up for sale. My plans where to do identical mods to your car :D
Have i missed it or do you have a dyno graph to see how the curve looks?
Cheers
Wait, it actually up for sale? :(
And yeah, where is the dyno sheet?
yeah, doesn't mean its going to sell though..
thinking $500 for a dyno sheet might be better spent on the next vehicle, butt dyno says its 320kw's, it was breaking traction in third today :P which only happens when its over 300kw's and Power fc says less than 20knock,
although a power run might be interesting for the record...
Power run = $50 :P
  • Like 1
really? is this backyard tuners lol.. i called 3times over the last month and must be backed up with work.
Anybody else around there that can do it for you? Surely its not that hard to get a dyno run...?
yeah the thing is I wanted the same dyno that I used for the GTX so I could have a direct comparison...
hmm, well I may be hitting the drags Saturday night, lol.. wont expect anything spectacular with hard tein suspension and shit tyres but will be fun anyway, anything in the 13's ill take :P
34GeeTeeTee- when you going to get a time at the drags, see what the HTA can do :)
Edited by AngryRB
  • 9 months later...
hmm, well after quite a while and going from trying to sell it to giving up and loving the rb again, ive got some passion back and have decided to build an RB30DET and im going to use a neo head to get the goodness of 9.5-1 and no
hydraulic lifters, current plan is to use a GT3076 with 0.82 external with power fc and go for 350kw's but use 1bar for daily and hopefully will make over the 260kw for a reliable daily with good low down torque. This is gonna take
probably 6-12months so a long haul project but hopefully worth it, cause I decided I wont sell the RB ever, RB for life people, fTW....
not sure what model this RB30 is but it has the oil feed and return for the turbo.. the build will be a journey for me im sure, been done before so hopefully not too much heart ache, just after a strong street performer.
Edited by AngryRB
  • 1 month later...
Ok, so its slow but the project has a heart beat still, lol.. Have ordered a GT3076 with 0.82external housing coming Monday, pictures then for those interested..
But to outline the plan and those in the know can add input if im going off track
ENGINE
Stock RB30 Block rebuild with Stock NEW RB25 pistons ( 1.5thou piston-bore clearance), rings, king bearings? , balanced, new RB25 Balancer, cleaned, Block decked flush
Reuse/check RB25 oil pump and bolt on all other stuff from my RB25
Compression- approx. 9.5 and dedicated E85 and see what she can do with 20psi on the dyno then pull back to 1bar daily :)
Face head and clean exhaust ports
Turbo- GT3076 0.82 external with a Tial 44mm and using stock manifold which will be port matched
Exhaust- 4inch dump and reuse my 3.5inch I have
Fuel- 1000cc Xspurts or thinking 2000cc Xspurts if they still idle etc properly cause they are shorter plus reg and rail
Other stuff
Splitfires and Z32 to work with my Power FC and Apexi AVCR
Purpose- Massive torque between 2500-6500rpm..
oh and I picked up some 34GTR wheels,will try to take some better pictures later.
Edited by AngryRB
  • 1 month later...
Picked up a GT3076 thanks to STT, and pulled the head off the RB30 to inspect the clearances, safe to say this isn't a 120k old engine as I was told, piston to bore clearance as double checked checked by the old man is 20thou. Must of been had a turbo on this and used at the track to get that much wear.
Considering going down the forged rods and pistons route so I can wind up the boost, im assuming I could run 25psi and it will choke off to 20psi up top.. thinking maybe I should of gone a bigger turbo but im sure ill be happy for a while.
anyway some pics, not sure why the pistons have a shiny mark on the top edges, im assuming that's from pinging?
20140820 111416 (640x360)
20140820 111444 (640x360)
20140812 193454 (640x360)
20140812 193017 (800x450) (640x360)
Edited by AngryRB
Yeah i maybe should of gone for a 3582 but ill try this out first and see how it goes, should give some great midrange and sound awesome thru the streets.
Edited by AngryRB
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
