Hids from eBay are hit and miss. Apparently Martin had a pair that worked great and another that flickered and died.
Make sure you get the right bulb. From memory, think that they are H1s. Install is easy.
I'll be doing my fogs and Chantelle's soon so if you want to duck by, contact me.
Hey mate I also had the yellowing effect on my headlights. I simply wet sanded my headlights lightly with rough sandpaper and progressed with the finest (used 5 different grades). I can't remember what type I used but between each sanding I attached a buffing element to an orbital sander and used some cutting compound.
The headlights look brand new. You can buy kits which are good. I did not use the uv spray to finish them off. Mainly because my vehicle is garaged. But it will yellow again down the track. If you do use the spray use an even coat and spray from a distance. You will get slight haze but can polish that out.
I have pics on my project thread I think.
That's a lot for guys, will be trying this method, I had a turtle headlight polishing kit for my old car and I followed step by step but it never really worked :/, and for the hids I think I found a reputable company called "auto plutonium" hid kit with Parkers to suit, if this f**ks up ill just try and find the whitest bulb
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
