If you have HICAS, then it's LSD. Most likely is AR-X models, however the lucky few have it as an option on the Rs/Rx.
The throttle reset is tricky to get right. Go through from the begging, ecu reset, throttle position learn, and then idle learn.
I'm giving the stag some love this weekend - will be cleaning throttle body (idle reset procedure didnt work, idles at 1400 in N), doing fluids in transmission, attessa and diffs. Do the diffs require LSD fluid?
Cleaning the throttle will only make it worse, make sure there are no vac leaks (the PCV hose is a common culprit) and no engine lights as it doesn't set the idle with an error present.
Change the transfer case fluid too. ;)
Oh - I read some posts on other forums where cleaning the throttle body helped get the idle reset to work. I'll pull it apart and have a look, but i'll be much more cautious after what you've said. Will the check engine light be on in normal driving if i have an error?
I sprayed aerostart on a few hose ends but didnt get any flaring, so couldn't find a leak that way. There is vacuum at idle, so if there's a leak its not huge.
For me attessa = transfer case, so that's in the list. Might do power steering fluid while im at it.
PN-MAD - I went through "Accelerator Pedal Released Position Learning" and "Throttle Valve Closed Position Learning" first - is that what u mean or is ECU reset different?
Yeah, that's what I meant.
It's pretty obvious when it does the idle learn. When hot, it revs up to 1800 rpm, then drops to the point it almost stalls, then goes back up to 600-650 and steadys. It can be hard to nail the timing, but it does work.
Last resort is get Nissan to do it with consult.
So I think I worked out why my M35 keeps throwing the code 1320. I took the coil packs off to change the plugs and half of the plugs were covered in oil on the outside. The tubes look like the seals are leaking and oil is getting past the O rings in the rocker covers.
Has anyone else experienced this? And where would i get rocker cover gaskets and the o rings.
Yes, it's very common.
But oil is an insulator, so shouldn't effect the coil packs. There is two ways of sealing. First buy whole new rocker covers. The seals are integrated. Or, two, try copper seal or something similar on the rocker covers to try to seal them.
Btw, wrong thread?
FYI - got the idle procedure to work - now idles at just over 600, and is completely smooth. Much better. Hopefully ill get more than ~300kms a tank now.... If not, ill swap the o2 sensor(s). ECU code was 0000.
Transmission fluid looked fine on the dipstick so i had thought it was probably ok, but when I dropped it, it was brown (not too dark) and stunk terribly. The transmission sump plug was completely clean, but ill do the transmission fluid again after say 500kms since its only 4 out of 10 litres from the sump each time.
Just get the Transgo shift kit done Stabby, it changes most of the fluid in one hit and is a must do mod for the M35, along with the brake wire cut. It sounds like the trans has been cooking, was there much red powder in the oil pan?
Not sure about red powder - i just dropped the fluid not the pan. Is the plug magnetic? Is the red powder metallic?
I'm trying to NOT mod the stag since its the daily. The GTR is for that stuff. Would you recommend the shift kit and brake mod for all use modes?
Edit:
PN - yep i'm in Sydney. Sounds like the shift kit is just better for any use type - right? I probably wont worry about the cooler tho since full synth fluid handles high temps so much better than non-syth stuff, and I wont be driving the stag too hard.
The trans will be fine in winter, it just needs a helping hand in summer really, to cool the fluid down and help it last. Heat is what kills auto's.
I would recommend the shift kit for any M35, however it's driven. The stock pressures are very low for comfort and soft shifts, but that is what promotes clutch wear. If the clutches go it could cost you 3-4 grand for a build, unless you can pick up a S/H one to replace it.
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
