I'm sure i'd be happy to show up.. but I don't want to be the only one there with a skyline thats nowhere as near as nice as the rest of the cars :(
Don't worry Mate, we can hang out in the corner like Bums and let the Cool Kids Strut their stuff. :thumbsup:
I'll prob come to this Eric, as i should be getting the GTR back any day now... any... day.... now... :blink:
Cool.
I saw your car being worked on today at Ultimate when I dropped mine off this morning.
Sweet. They know i want it back now haha! Can't wait to get it back. It will be a completely different car.
Cool.
Don't say that =(
Edit: full meguiars detailing products on stand by, im going to have a ball :wub:
^ Lol - It could be someone else's GTR :P
Edited by Anfanee
Sorry guys but are part in this has been cancelled.
I think they wound up getting some more things in that people will pay for and have run out of space.
I was really looking forward to all of us catching up at this.
Plus the kids would have loved it!
Sorry guys but are part in this has been cancelled.I think they wound up getting some more things in that people will pay for and have run out of space.I was really looking forward to all of us catching up at this.Plus the kids would have loved it!
Bugger. :(
Should just crash it anyways. :thumbsup:
I actually thought about charging for rides, but then there are some serious insurance issues etc. on behalf of the school. LOL
Yes, lets crash it.....I just can't go home after that! LMAO!!!
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
