Its most definately not needed, though jap cars are tuned for fuel even higher than our premium, u will get better economy due to higher efficiency from premium, but no noticable power increases, unless u advance ur timing with the better fuel.
I ran my skyline normal BP unleaded... never had problem
in few months I squirt some octane booster... that's aobut it.
really there is no need use high octane in NA cars.... as long as unleaded is Clean enough.
cheers
Joe
ps. I dont take any responsibility for any action due to above commments... :D
no need for premium as mentioned...
premium is generally only needed on engines that are put under a bit of stress, to stop the fuel combusting before the spark plug ignites it... your N/A shouldn't have this problem..
For some cars yes, for others no. My Bluebird (SR20DE) ran on normal happily, but my R32 Skyline GTS (RB20DE) pinged pretty bad on anything but premium, and thats at stock timing of 15 degrees too. I could of reduced the timing to run normal unleaded, but that defeats the purpose really as you get worse fuel eco with reduced timing (as well as reduced response)... Try it, and listen very carefully with it loaded up some hills and some detonation isn't very audiable...
I use premium but not always 98RON (only when its at the same price as premium, which is really really rare :bs!: , and its more suitable for turbos and really modded n/a anywayz). I find its more economical, you get more kms from premium rather than using normal unleaded. Not sure about performance though, but yea worth the extra 5c and u get cleaner injector i guess.
Experiment a little see which ones the best.
p.s. as PVA_Glue says...I dont take any responsibility for any action due to above commments... :rofl:
Thanks for the reply guys, I've got a Turbo33 at the moment but am in the process of selling the wifes VTSS(supercharged V6), I wanted to get her a WRX but she doesn't like them, she'd prefer a Skyline so I thought to go NA as it will save us on insurance, fuel and hopefully the initial purchase cost, plus I think they would go quite well as my GTS-T still accelerates nicely even when not in boost.
Turbomad: my mate went for a n/a for much the same reasons as you mention.
He is very happy with his purchase so far.. and saved $5k on what a decent turbo would cost + the extras. Exactly the same features and look anyhow other than the gofast bits. Still drives very nicely, and just a good car all round. Nothing local could offer same specifications or features for a similar price.
Insurance was around $800 through justcars for an n/a too for a 25y/o+ driver.
Can you actually have premium and 98RON mixed together in 1 tank, like half of each? Can this do any harm?
e.g. you have half a tank of premium left, and than u found out 98RON is the same price as premium and thought u'd might as well fill up.
Please advise.
BTW, this is for a N/A not Turbo line.
I always use 98 ron just for the peace of mind, and in my opinion the car runs a lot smoother on 98 than premium (95). Once I added octane boost to 98ron fuel and it ran smoother again. They are tuned for 100+ron fuel so you might as well get as close to that as you can. Sure its probably not necessary, but why skimp? Asuming you save 5c per litre by getting premium instead of 98, this is only a saving of $3 per tank - which is hardly significant.
Cheers
Greg
well actually the two different octane ratings means that no the fuels won't mix in the tank. The specific gravity of the fuels is different, due to their different octane rating, the 98 is denser and will make it's way below the 95. But yeah no problem in putting half and half in the tank.
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
