My cold oil pressure is probably 130-140 cold at idle and takes about 15-20 minutes to get down to 80 psi but as soon as to rev it its 100 again and i have troube with it pushing oil out
Know i have drilled the head oil drains out to  9.5 -10mm from the 8 thay are as it ses to do to match the gasked i have got a 1mm restrictor in the block one blocked of a 1.2 vvt external oil feed the oil hole in the back of the head 20mm going in to the turbo drain line that is 20mm stock rb25 cam covers with -8 breathers in to a open catch can under the car i have a n1 spline drive oil pump from spool imports a asr race sump think its a 8.5 liters if this helps iam just over it thanks sorry for not putting full info
  • 3 months later...
Sorry for bumping an old thread
pet vl, did you find a cause for your high oil pressure? I have a similar setup in my 25/30 but with a 25det pump and on the dyno I am seeing 8.1bar of oil pressure through a run. Oil temp is 82. I am using 10w60 edge
I have three questions for this
Is the oil pump bone stock ie. original springs, no shims?
Are you relying on the OEM gauge in the dash for "accurate" pressure indication?
Have you tried a different grade of oil as per Bob's comment?
Is the oil pump bone stock ie. original springs, no shims? Yes bone stock brand bew RB25DET oil pump
Are you relying on the OEM gauge in the dash for "accurate" pressure indication? i have a GM 130psi oil pressure sensor feeding my Vipec ECU, will be getting a mechanical gauge to confirm the readings
Have you tried a different grade of oil as per Bob's comment? not yet, i haven't touched the car since it came off the dyno.will look into a 5w30/10w30
Hi Dale,
please see my answers underlined.
Double check the input scaling of that sensor in the relevant ANV table, such that the ECU is correctly interpreting the voltage input.  If you had short term access to a known/good mechanical gauge it might make for good cross checking.
After that it would be well worth changing the oil grade, and do a back to back comparison for changes.
thanks Dale. the sensor is the same type that i have on my fuel pressure which from injector pulses is accurate for what we calculated the engine needed.
that is the plan at the moment, try a mechanical gauge, then different oil, then if that doesn't work the sump will have to come off and see if the bypass valve is the issue.
i see other people had issues with Edge 10w60 on their RB30's (cubes) so hopefully it turns out being as simple as the wrong oil
  • Like 1
  • 5 years later...
On 5/12/2023 at 8:03 PM, DriftSpark said:
What happened in the end? @Looney_Head
Hi,
i ended up pulling the pump off and porting out the oil by-pass and going to a 5w/30 oil. that has fixed it. i now see 100~PSI peak
    • Kinda glad I never got to this ..    https://www.facebook.com/groups/1483859159195077
    • @GTSBoy This method was able to get readings of -10 to -2, so it looks like its monitoring.  Now I need to figure out why the vacuum on the line provided isn't alternating with manifold pressure.  I went with 2 lines that an RB25 tuner recommended but I'll get a longer hose and try directly off the back of the manifold.  He may have been used to OEM intake setups while I have a DBW setup that removed the MAF and IACV.
    • I work at a car detailing and tinting shop called Quark which gets all manner of German cars in usually (mainly due to a contract with Mercedes Benz Kita Osaka, BMW Nishinomiya and others) but every once in a while something special comes in, like a fully restored 1972 HS30 Nissan Fairlady 240ZG... The shop owner had immediately started applying film to the windows as soon as it was in the shop so the interior was completely covered in towels and plastic sheets. But I could get a few photos of the engine bay which was restored like new. Such an amazing car to see in pristine condition in Japan these days.
    • Was going to say the car pulls up nicely everywhere, especially going into that last long right hander before the main straight. Looks like a lot of fun.
    • Hey Dave, welcome aboard! Good to see another soon-to-be Stagea owner here. The wagons are awesome — plenty of space, still got that Skyline DNA, and loads of potential if you’re into mods. Definitely post up pics when you get it, everyone here loves seeing new builds. What model/year are you looking at?
