I've lined up an r33 rb26dett with ecu & loom & r34gtt manual gbox.
I believe both motor & box are pull so no probs matching them up
Modified RWD sump & custom tail shaft.
Considering r32 ecu & nistune for tuning.
This is going into my z31.
Any recommendations or things to avoid - lookout for ?
Cheers, Paul
Edited by pauls
https://www.sau.com.au/forums/topic/427667-r33-rb26-into-89-z31/
Bolts? I was thinking blu tac!
There's a few pics floating around and a heap of BS chit chat, but no actual detailed rb26 build threads anywhere that I can find.
Would have been nice to know specific nuances about the rb26, GTT box or even better tricky bits encountered during upgrade, but seems will learn it all on the job.
Str00th did the same to a 200zr that was up for sale around mid 2011 but no real details or info on where it went?
PMd str00th ages ago and his insight was 'don't do it'. We all know what the natural instinct is when we hear that response...
Cheers, Paul
Edited by pauls
depends on the z31
is it vg or a rb
if rb its a bolt in job
if vg you need to rear mount the sumop ( little bit more work)
gtt box slapps straight in minor cut and shut of the cross member. pull push doesnt mateer just determins what clutchand slaev you use
wiring is easier in the z31 as it old school
ic is a bit of a pain but once again really not that hard
and you need to run a header tank on teh radiator otherwise its a bitch to bleed
one of the easier conversions youw ill find
I think you should expect the top of the radiator to still be a lot lower than the top of an RB. Hence a header tank. Way back in the way backs, the VLs used to crack heads a lot because mechanics didn't bleed them up properly, and the nose on a VL is not as low and pointy as a Z31.
  • 7 months later...
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
    • Agreed, and in particular the earth strap that should go from the subframe to the chassis but it often broken or left off. There is a section in the R32 workshop manual you can follow for troubleshooting if you don't see anything suspicious, and depending where you are (there is no location on your user profile) you should be able to get your hands on a second hand replacement unit still if needed
    • Yeah they mention as a R34 for 2.5 Turbo...but then again thos "small" were also for R34 by that different site. But i look into it and that 310mm EBC is for R34 GTT. And by those you linked the specs are the same 🙂    EDIT: I found these on one site here: DBA 4000 series T3 DBA42304S They are 310mm...and it says are for R34GTT...are there good? EDIT2: ok they have pads too.  What "color" should i get for street use? I dont want/need some noisy ones...(and if they are not that dusty that is good too)
    • Yeah, shame. Maybe  driver's carpet is available 🙏. I am waiting for both amayama and nangun to confirm.
