So after cleaning my car today I've noticed this part on the driver side of my door is cracking off. This can be seen in the photo below.
How much would I be looking at to get it fixed PROPERLY and painted?
that looks like rust to me. i had the same on my passenger door. cost me about $300 to repair properly, respray, colour match, and blend.
in my case, there was a piece of sound deadening mat thingy stuck to the inside of the door right behind the spot. it was collecting water and sitting there causing the rust bubble.
I wouldnt be surprised if you find the same with yours, coz realistically, there's no other reason for a spot in the middle of a sheet to begin rusting.
a replacement door might be cheaper to buy, but then there's little chance the colour will match perfectly.
  • Like 1
Ye pretty sure it is. Bought it like that. Previous owner said when he imported it came with the car. Hopefully doesn't fall off anytime soon because so costly to fix.
$280... wow.
My old GQ patrol had this sort of rusting all around the roof gutters, about 45cm of in total around the whole car.
Also roof racks had caused rust lines where they scraped paint along the top of the roof.
To get it all repaired and the entire roof resprayed cost $400.
$280 for that incredibly tiny area is a bit insane in my eyes, or maybe I just go to a cheap bodyshop. (that being said, nothing went wrong with the repair on the patrol in the 5 months I had it until it was sold).
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
