2013/14 Sau Qld Annual General Meeting (Agm) And Committee Elections
Yup. Just casual/smart casual. I'm straight from work so suit it is.
It's more sprining coin for it at the moment, Between House, Car and Kid's justifying membership to the minster for war and finance is something I am trying to get for Father's day.
Ahh yes. Can appreciate that. Our minister of war and finance is also an exec so that makes it a little easier. :)
The kid is also the unofficial club mascot.
  • Like 1
ANNOUNCEMENT
Due to both Scott (Sabbai) and myself being nominated for the President's position, there will be a vote tonight. Have a long hard think about who you wish to have as the head of your Club. Chants will be collecting votes whilst I exit the room. Scott has taken exiting the room to a whole new level and is currently in the UK :P
Well that just made things difficult.
From what it looks like on google maps just like your normal business complexes with car parks out side place of business.
yeah, but the key question is will there be any available at close proximity of the club :dry:
Guzman Y Gomez at emporium.
Valley... near west end...
El Torito is delicious and in West End. Also, in South Brisbane (Southbank to be precise) there are several delicious burrito bars.
Dead smack outside the doors I believe can't get much closer XD
    • So I actually had the cover off my car today, here is a (bad) pic of the setup. I have an oil cooler thermostat block, the temp sender is straight in there. The pressure sender has a short AN line to a T piece which is mounted (hopefully cable tied counts as mounted....) on the chassis. BTW every fitting you could ever imagine exists....just depends what they cost and how many you need. Raceworx AN adapters are here: https://raceworks.com.au/fittings/adapters/, I think you said you need BSPT to AN (https://raceworks.com.au/fittings/adapters/bsp/tapered/an-to-bspt-adapters/) and AN to NPT (https://raceworks.com.au/fittings/adapters/npt/) BTW, braided line is super simple to make. It looks intimidating, is not.
    • Perfect day for a pie, really needs a soft top in this weather though
    • Prime parking, she is a little girl...LOL
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
