My R34 rear brakes are squealing bad. its only coming from the left rear side.. I have read heaps of forum for a solution but could not fix it.
The squeal comes only on low speeds 0-30km/h while breaking. Like when im trying to stop in a trafic light or just slowing down to stop.
So far I have changed the Rotors (RDS Slotted)
Changed the Pads (Bandix Extreme)
Installed a new shim kit with backing plates..
Tried Copper grease on all the metal components except on the rotters and the front of the brake pad..
Grind the pads on concrete..
My mechanic told me that the calliper and the pistons are working fine..
I can’t think of anything else to do.. The squealing noise is too loud.. Need help please..
https://www.sau.com.au/forums/topic/428011-r34-gtt-rear-brake-squeal/
Change the extreme pads out, for general CT pads. Mine use to squeal and just got new pads and tapered the edges on them so they didn't hit the lip on the rotor ( Couldn't afford new rotors ) Most people i've talked to about say only use base pads with slotted/drilled rotors
    • If you are Ecutek tuned then these TCU tunes are anywhere from $550 to $700 usd. If you are not ECUTEK tuned, then it gets costly!
