10kg/mm springs would be shocking on the public roads. Unless you live in an area with smooth roads.
Jump onto the Otomoto website and have a look at their range. HSD HR (what they usually sell) will be fine. 8kg/7kg (f/r) is plenty stiff. If you want less roll, install bigger anti-roll bars on your car. You can also order alternative spring rates.
I have been reading up quite some threads now and looks like Bilstein shocks with lowered King or Whiteline springs is great for the street. What I would like to know is what other parts I need to get like camber/caster tops, bump stops etc?
This looks like a more expensive option than BC BR coilovers from Street To Track at $1150, but the BC BRs would be much stiffer right - even with 6/4kg front/rear springs and softest damper settings?
Where is the cheapest to get Bilsteins, the tops and springs and which Bilsteins? Are KYB shocks even a consideration, its purely a street car, needs to be comfy, good handling- I need lots TRACTION aswl- and lower than stock..cheers
It's a Skyline. You don't need any fancy tops. They are suspension units, not struts. Caster, camber etc are all set elsewhere in the suspension.
Yes, even the heaviest Kings Springs are still less than the 6/4 rates on the BCs.
You need to get Bilstein B6 dampers.
KYB are not really an option. The KYB twin tubes are not comparable with the good Bilsteins. KYB adjustables are not an awesome adjustable. I have a pair of KYB twins in the rear of my car. Have had for years and years. They are on the list of things to change.
Thanks mate, I meant the Bilsteins or any shocks dont come with the bump stops and top plate/washers that bolts to the chasis right? Maybe I could re-use my Cusco ones if they fit.. :S Is it ok to get used Bilsteins? Probably on this forum itself.
from memory, the Bilstein B6 will just reuse the stock bump stops and if not i think your mechanic should be able to source these easily. I think used bilsteins is fine BUT as with any second hand coilovers/shocks, you really need to know how much wear they've had, how old, how many KM etc. Get your Bilsteins from Gary (SK), i think his contact details are somewhere around on this forum, he has direct contacts there - i got mine all 4 delivered for approx 1000$ a few months ago and that was when the AUD was on top, now, i don't know how much it'll be. but give him a yell.
King springs are around 300$ more, so all up, it should cost ~1400$ give or take.
Thanks darksky, I just called Heasemans -$620 for a PAIR of Bilsteins for R34, then I have to get bumpstops, springs, shock top plates from a wrecker etc. Looking at 1600-1700ish already just to get more traction out of my setup. Not worth it imho, I am still rather keen on the Billies though. BC BRs at 1150 would be much better value but maybe stiffer even on softest setting. Wonder how 'rubbish' KYBs are compared to Bilsteins if Im forced to go down that way. The guy at Heaseman's told me my ride height is determined by the springs and not the shocks, I did think the shocks also play a small part in height reduction from stock :S
I have Bilsteins with king springs all round in my R33, i got them organized through GSL RallySport on here. I think i got them for roughly $1200 when they had a deal going on. They might be able to help out.
Really nice especially compared to stock, have been in a few cars which have your typical jap coilovers and they are alot smoother. But still nice and firm with out being over the top, however i did do a major overhaul when i got them installed with sway bars and bushes all round so its hard to tell how much each item did in terms of steering response.
rondofj, contact Gary! he will give you a quote for all the items you need - just tell him what you want.
mystery kid, i have spoken to some members here who have had ZZRs in their car, they said it was fine for streeting, however i have also spoken to mechanics who told me that ZZRs are same as BC BR just painted differently - how much better would you expect their suspension to be, at the same price?
http://www.otomoto.com.au/p/8472344/hsd-ad-type-coliovers-for-skyline-er34.html
These are heaps comfortable on Sydney roads (compared to the stiffer stuff, including the Blitz ones from JustJap). HSD AD is on S15 and street only. Blitz ZZ-R on S14 (think they're 8kg/6kg f/r) and car is street/track. For road only, AD for sure (if they made them for GT-R I would have them right now). If you're going to take it to the track or want a "stiff" setup, then HSD HR/BC BR/Blitz ZZ-R. All for <$1,500
Bilstein is more expensive but you get what you pay for. Their low range control is really good (ripple control) mainly due to the large piston diameter. If you can afford it, then get them.
Hey Nizmoman thanks for the heads up, wherebouts are you in Sydney do you mind me checking your car out with the HSD AD, maybe in the weekend- I would really like to take a short ride in any Skyline/Silvia with either HSD/BC coilovers or Bilstein struts. I'm in Parra, can drive up to any kind fellow who will allow me to get a feel for his suspension setup haha.. Just need to compare against my current Cuscos and get what I need after trying..
Sorry man, should've mentioned that the cars I mentioned are my friends. I have old Ohlins dampers and Eibach springs on my GT-R. Also have flogged out upper front arms so the experience isn't pleasant.
S15 mate has the HSD AD dampers on full hard and it's still pretty comfy (on par with the Blitz on soft on S14 mate's car).
Trust me, the AD will be better than any random Jap suspension for Sydney. I couldn't believe the ADs were that soft, perfect for street (good body control and ripple control). Plus, it's a thousand bucks. Wind it up and down until you're happy with height. Win in; go for it!
    • GCG is a good company, they're a major distributor for Garrett in Japan as well.
    • Nah, OEM washer bottle and brake fluid reservoirs are fine I don't know what it is with the plastic that Mazda used, some plastics, like the washer bottle and brake fluid res are fine, and still look new after 20 years use, where as the coolant expansion tank, and PS reservoir, that I replaced with new OEM items when I first got the car, turned yellow and started getting brittle a few years later If the dirty yellow stained plastics didn't trigger me there wouldn't be an issue, but they did, much like the battery bracket....... Meh As for going back to work full time to support car stuff, nope, why, because I own a Mazda NC MX5, not a Nissan R series Skyline 🤣
    • I've never heard of CJ-motor, so can't advise you on them. I'd just go straight to GCG for a GCG highflow though. Seems no point to use a middleman. I'm somewhat surprised that the price on the CJ site is lower than the GCG retail price. Even though CJ would get a discount of some sort, you would hardly expect them to give up so much margin. Maybe the price is out of date? Having said that "I'd go to GCG"...when I did my highflow, I went to Hypergear. I did this https://hypergearturbos.com/product/rb25dethighflow/#tab-dyno-results with the R34 OP6 450HP profile. With the BB centre (extra $400) and intially with the standard boost actuator, but I eventually got him to send me the high pressure one when I got to the point of being able to actually use it. Ends up costing the same sort of money as the GCG highflow, but this is, of course, the turbo that I KNOW has a shorter length core and so moves the comp cover rearwards. The GCG apparently doesn't do that. My mechanic also swears by the GCG highflow, given that we have another turbo rebuilder who does something essentialy the same as theirs, using Garrett wheels. He says it stands up at really low revs and makes good power. I haven't pushed my HG highflow past ~240-250rwkW yet (should have a little more in it, but unclear how much) and it does have a fairly gentle boost ramp. OK, it's much better now that I have gotten my boost controller tuned up on it.  A lot of my earlier unhappiness was because I couldn't keep the wastegate flap as closed as it needed to be (including some mechanical issues). I'd still prefer it to boost up nearly as quickly as the stocker, and it certainly a bit slower than that. So maybe the GCG one is worth the first look (for you).
    • Ok thanks 🙂 I will higly consider this. Any "known" company for a good reviews and experience to send that off? Is that CJ-motor good one? Or go straight to GCG site? I need to use VPN to even find some of those "shops" let alone access them 🙂
    • You can literally put in as much WMI as it takes to quench the combustion totally (and then back it off a little, obviously), and it will keep making more and more power. The power comes from the cooling effect of the water (and the meth) and the extra fuel (the meth, which also has massive octane). It is effectively exactly like running E85. One might be slightly better than the other, but they are damn close. But with either you can lean on the boost or the timing (or both) waaaay more than with just petrol and the results are similar. Here's the first thing I googled for an anecdotal bit of evidence. Can't access the attachment without being a gold member, but it is there for the getting if able to, or searched up elsewise perhaps. https://www.hpacademy.com/forum/general-tuning-discussion/show/wmi-vs-e85/
