  • Replies 43
Cheers.
Think I'm going with the RaceQuip stuff, it's very good value.
Further to this. On the topic of neck protection, I was just going to grab one of those FIA spec 2" tapered foam donuts that all my mates where in speedway but I'm wondering if something lie a Leatt brace is a better choice (as opposed to full fledged Hans which would require a new helmet for me too).
Have you ever picked up and felt a race suit? Tried 1 on?
A friend and myself decided we were both going to buy a good suit because we were on the serious side of private trackdays and just wanted the extra safety that a suit provides. Our plan was to go to a local retailer, work out what we wanted then order it from overseas for about 25-30% discount (same brand, same sizes as Australian retailers).
I can tell you now that before buying my Sparco safety gear I went in to the Australian Distributor a dozen times before handing over any cash. I spent probably 2 hours trying on different model Sparco suits and I can tell you that just because they were the same size (number) they certainly weren't the same fit. Some were slightly longer in the legs but tighter around the belly, others were longer between under arm and hips, they all fit different between the various models even though they are made in the same factory and the same brand. Even after all that time spent trying on I got the suit home ($1,000) wore it around the house for a few hours over various nights just to get it to adjust and also to get used to the feeling of being in a suit like that and I still took it back and got a higher model that fit slightly better (Sparco X-Light $1,500).
The difference between the $400 "overalls" and a $100 proper suit is massive and then up again to the $1,500 suit was quite astonishing. The weight differences are amazing and the additional fire protection is also considerable.
Edit: The same can be said for helmets.
Buy the $150 job from a motorbike shop and you will get only $150 worth. The more expensive they get the lighter they are, the better ventilation they have and much better face screens on them.
It really comes down to, how much can you spend and the more you spend the safer and more comfortable everything will be.
I've been speaking with RaceQuip and going over specific measurements.
To ensure its comfy I'll be getting it a tough larger so it should have plenty of space (also to accommodate any growt from gym).
As for safety I was originally just getting a single layer but will eat a multi layer SFI 3.2/5
Cheers for the feedback.
We'll see how I go with the HANS stuff, I may go for it, in the meantime I will try out the donut just for "something" and then I may move to a new helmet and HANS in August if I get a bonus at work.
Went for a multi-layer 3.2/5 suit, shoes and gloves which are a bit better than than the 3.2/1 rated single layer stuff.
$324 delivered for everything, that suit is normally $300, got it for 84, STEAL.
Got all my gear, quality looks decent.
Gloves and boots fit well, suit is too big despite me getting myself measured 3 times, they are VERY generous sizings.
L would be been fine but according to my measurements the L would have been really tight and the XL was what I needed, but the XL is for more portly gentleman.
So will have a race suit for sale.
For the lolz. I know they are supposed to be loose but maybe not this loose.
The issue I may have is the inseam and leg feels fine.
I'm more legs than torso.
I may have to buy the large and keep whichever suits best.
Better pics.
For those that wear suits how does this look?
When I sit I wouldn't want it any tighter across the shoulders/lower back but it's puffy ass in the gut/crutch.
I have clipped the belt in that pic to show where I'd add a velcro tab to pull it in.
How loose is too loose...
EDIT: what's the go with the captcha's?
Edited by ActionDan
I say in the car and it felt fine, if anything I wouldn't want it tighter around the arse/lower back when you reach forward. Otherwise it Bunches up on the sides/in the gut.
As stupid as it sounds, just don't wanna look like a clown and its pretty floaty if I don't wrap the belt right up.
OK, My mates all seem to think it's fine but interestingly the guy at RaceQuip said I should go for a large and the XL is too big for me.
I'm going to buy the large, should take another 10 days or so to get here, compare it then sell whichever I don't want.
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
