So at Matsuri, the car went from looking like this...1922014_639959332706435_1934333717_n.jpg
...to this... :/20140223_090210_zpsqarlvnvc.jpg
The new front end setup was just too stiff, consequently, the car had a lot of understeer. In hindsight, I should have tried to tune it out instead of driving around it. Combine this with copious amounts of rear grip, and running new tyres at low pressure, meant the car was very quick and on this one occasion the speed caught me off guard.
Sorry to see you had a "mishap" on the weekend man, any damage to the wheel or suspension?
Considering, that could have been a lot worse, and to be honest for a drift matsuri, if that's the worst that happened the car held up well ;P
Thanks Danial, Tim, you are right, it could have been worse. Because the Ikeya Formula control arms are so strong, they transferred all the force in to the engine subframe and k-frame, elongating the mounting holes for the pick-up points and bending it out of shape. The arms actually look okay, but I'm yet to pull it all down. Plus I think the rad support is a bit out of shape.Only the lips of the rims we damaged, so they should be fixable with some work.
  • 4 months later...
It's time to update this. Unfortunately, it's not going to be a 'big reveal', that some, myself included, may have be hoping for. Truth be told, the car has been sitting in a corner of the workshop being neglected since the crash. For some reason I took the whole ordeal to heart and I'd be lying if I didn't say that the black dog has reared its ugly head again. Nonetheless work has begun, and progress is progress.
The first thing to do, was to change out the bent crossmember. In lieu of this, I ordered a set of Nismo engine mounts.
To support the motor while I dropped the cross member, I fitted this home made engine stand.
Out with the old.
As you can see, the LH engine mount was broken. This confirmed my earlier suspicions.
It took a fair old hit, and you can see here, just how badly it was bent.
It even bent the bolt.
In with the new.
I also took the liberty of replacing the castor arm brackets, but neglected to get a picture of this. The Nismo gearbox mount fitted up.
The long Nismo box, pictured earlier, contained this boot brace which I fitted to help stiffen up the rear end.
More to follow.
Glad to see some progress Tim! Can't believe how bad that subframe was, was a bigger hit than I thought!
Hope everything is going well for you mate, can't wait to see you back out on the track :)
  • Like 1
Continuing with the N1 theme.
A pair of brand new N1 headlights. The crash broke all the mounts on my projector headlights, and while I do prefer the look of the projectors, I just couldn't go past this cheaper and cooler option.
    • Cheers. Skyline is back on the menu, can’t get rid of it. It’s like a child you don’t want, or herpes
    • I got back to Japan in January and was keen to get back on track as quickly as possible. Europe is god-awful for track accessibility (by comparison), so I picked up a first-gen GT86 in December just to have something I could jump into right away. The Skyline came over in a container this time and landed in early January. It was a bit battered after Europe, though—I refused to do anything beyond essential upkeep while it was over there. The clutch master cylinder gave out, and so did the power steering. I didn’t even bother changing the oil; it was the same stuff that went in just before I left Japan the first time. Naughty. Power steering parts would’ve cost double with shipping and taxes, so knowing I’d be heading back to Japan, I just postponed it and powered through the arm workout. It took a solid three months to get the car back on the road. Registration was a nightmare this time around. There were a bunch of BS fees to navigate, and sourcing parts was a headache. I needed stock seats for shaken, mistakenly blew 34k JPY on some ENR34 seats—which, of course, didn’t fit—then ended up having the car’s technical sheet amended to register it as a two-seater with the Brides. Then there’s the GT86. Amazing car. Does everything I want it to do. Parts are cheap, easy to find, and I don’t care what anyone says—it’s super rewarding to drive. I’ve done a few basic mods: diff ratio, coilovers, discs, pads, seat, etc. It already had a new exhaust manifold and the 180kph limiter removed, so I assume it’s running some kind of map. I’ve just been thrashing it at the track non-stop—mostly Fuji Speedway now, since I need something with higher speed after all that autobahn time. The wheels on the R34 always pissed me off—too big, and it was a nightmare getting tires to fit properly under the arches. So I threw in the towel and bought something that fits better. Looks way cleaner too (at least to me)—less hotboy, less attention-seeking. Still an R34, though. Now for future plans. There are a few things still outstanding with the car. First up, the rear subframe needs an overhaul—that’s priority one. Next, I need to figure out an engine rebuild plan. No timeline yet, but I want to keep it economical—not cutting corners, just not throwing tens of thousands at a mechanic I can barely communicate with. And finally, paint. Plus a bit of tidying up here and there.
