So at Matsuri, the car went from looking like this...1922014_639959332706435_1934333717_n.jpg
...to this... :/20140223_090210_zpsqarlvnvc.jpg
The new front end setup was just too stiff, consequently, the car had a lot of understeer. In hindsight, I should have tried to tune it out instead of driving around it. Combine this with copious amounts of rear grip, and running new tyres at low pressure, meant the car was very quick and on this one occasion the speed caught me off guard.
Sorry to see you had a "mishap" on the weekend man, any damage to the wheel or suspension?
Considering, that could have been a lot worse, and to be honest for a drift matsuri, if that's the worst that happened the car held up well ;P
Thanks Danial, Tim, you are right, it could have been worse. Because the Ikeya Formula control arms are so strong, they transferred all the force in to the engine subframe and k-frame, elongating the mounting holes for the pick-up points and bending it out of shape. The arms actually look okay, but I'm yet to pull it all down. Plus I think the rad support is a bit out of shape.Only the lips of the rims we damaged, so they should be fixable with some work.
  • 4 months later...
It's time to update this. Unfortunately, it's not going to be a 'big reveal', that some, myself included, may have be hoping for. Truth be told, the car has been sitting in a corner of the workshop being neglected since the crash. For some reason I took the whole ordeal to heart and I'd be lying if I didn't say that the black dog has reared its ugly head again. Nonetheless work has begun, and progress is progress.
The first thing to do, was to change out the bent crossmember. In lieu of this, I ordered a set of Nismo engine mounts.
To support the motor while I dropped the cross member, I fitted this home made engine stand.
Out with the old.
As you can see, the LH engine mount was broken. This confirmed my earlier suspicions.
It took a fair old hit, and you can see here, just how badly it was bent.
It even bent the bolt.
In with the new.
I also took the liberty of replacing the castor arm brackets, but neglected to get a picture of this. The Nismo gearbox mount fitted up.
The long Nismo box, pictured earlier, contained this boot brace which I fitted to help stiffen up the rear end.
More to follow.
Glad to see some progress Tim! Can't believe how bad that subframe was, was a bigger hit than I thought!
Hope everything is going well for you mate, can't wait to see you back out on the track :)
  • Like 1
Continuing with the N1 theme.
A pair of brand new N1 headlights. The crash broke all the mounts on my projector headlights, and while I do prefer the look of the projectors, I just couldn't go past this cheaper and cooler option.
    • @Kapr Haha yeah thats the one. I missed that you had a built up engine, I wouldn't want to run it on there either then. It was good in my situation just to replace the original turbo on a stock engine. @MBS206Yep definitely not a replacement for anything name brand
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
