Step 1. Undo the clamps on either side of this U-Shaped hose, then remove the hose.
Step 2. Undo these 2 screws, it will allow you lift up the intake pipe giving you more room.
Step 3. Loosen the 2 adjustable clamps on the hose connecting to the plenum, also the other small one seen in the picture.
Step 4. Disconnect the loom plug (may vary in appearance). Then just move 2 disconnected looms off to the side. You don't have to remove the 2 circled screws.
Step 5. There are 8 allen screws to undo all the way along the plastic cover as circled below. Once you have removed them all you can then slide out the plastic cover.
Step 6. Once you have removed the plastic cover you'll see the lead pictured below, with 6 looms connecting to the top of each coilpack, undo the looms that connect to the top of each coilpack. Then remove the small screws that hold the length of cable in place and remove it.
(Coil Pack Lead)
Step 7. Now, at this stage you will see the top of each coil pack, I pulled out the whole cradle and coil pack as described next but you dont have to that. You can just remove the screws that hold each coil pack in. This how to pull it all out.
Unscrew the gold/bronze bolts that hold the coil pack cradles in place. There is about 6 or 7 of them. Once they are removed you can pullout the coilpacks and cradle to see the spark plugs underneath.
(Top of Coil Packs)
(Coil Packs and Cradle)
Step 8. Now that you can see inside, it is recommended that you spray some compressed air inside to clear/dislodge any crap that may fall into the combustion camber once you have taken out the spark plugs. Now remove the spark plugs and put in the new ones!
Step 9. Put it all back together.
Edited by Shane
  • Like 1
https://www.sau.com.au/forums/topic/42819-rb25det-changing-the-spark-plugs/
  • 4 weeks later...
  • 2 months later...
  • 1 month later...
had the plugs in mine done a few weeks ago. Used NGK iridiums to suit rb25det.
Took in for a tune the other day and had problems. Apparently I should have used NGK iridiums to suit rb20det as they run cooler. She runs nicely now and the plugs are cheaper!
  • 9 months later...
anyone know if you just pull the coilpacks straight out once the two screws are removed?
seems like the pack is still attached to something underneath and i'm not game enough to put too much force into pulling it out without knowing.
Hey so which one should you use?
rb20 or rb25 sparks? should you also get it tuned after the installing the new sparks?
I love this tutorial.
Found it over a year ago, made it into word doco format.
Printed it off in colour and make sure it's around everytime i change em juts to be sure.
Thanks matey !
Awesome job!
Used the changing oil one for awhile but thats piiiss easy so don't need it now.
(but not easy if you've never done it before, which is where i was awhile back)
The best thing is, changin oil and spark plugs must be 80% of what a 'service' is and you never know exactly what they're doing........so get in there guys and do it yourself.
  • 4 weeks later...
Would the author of this tutorial please add:
Loosen the plugs, BUT before removing them, blow the area thoroughly clean with compressed air.
Can't believe people still pull dirty plugs and wonder why they suddenly develop a miss after dislodging crap into the combustion chamber.
Regards.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
