Hey everyone, I am on my p's and my 93' r33 is my daily, with 150k and climbing on the clock with leaks and ticking from the motor I have been thinking about sourcing my self a rb25de neo with lesser k's so I am seeking advice from you guys, worth doing? Straight fit? Will it allow me to use same diff gear box, and if that is all good would it be better to grab a after market ecu or stock r34 ecu? Note I know my car is not worth spending big bucks on and I do have the plans to upgrade to a turbo model, any advice or tips I'd appreciated
Cheers
https://www.sau.com.au/forums/topic/428203-rb25de-to-rb25de-neo-worth-it/
Thanks for the advice guys, thought about dropping in a DET but how will my brakes handle it? In a sense to do it proper and safe my brakes will have to be upgraded right? And running gear? Even tho I will have to leave the motor stock to not to attract to much attention right?
You're on your P's, so forget about turbos.
Where is it leaking oil from? Ticking sounds like oil is too thin. Not sure if it got worse or you bought it like that. Try thicker oil.
Wait until you're off your P's then buy a turbo one (or sell your car and get an R34).
I wouldn't drop in a DET due to the cost factor and all the bullshit that goes along with it (mod plates ect) and after reading on here and how so many people say not worth spending money as you can't get any real gains, plus I'm not made of money lol, my only goal for this car is to keep it clean and respectable (best I can for a non turbo) and learn how it handles and get a better under standing of the RB'S and if I learn how to use what power my car does have more efficient then I would be pleased
Yeah just keep it serviced regularly, etc. Take it to track days, skid pans etc to learn how your car handles in different situations. Build your driving skills up. Once you get a turbo (after a few years of experience), you will appreciate it more and more importantly, know how to control it a lot better.
i recently put a neo in my 33 after finding out the crank key way was thrashed out. the big costs are as follows: engine, wiring, ecu, clutch.
all up i spend about 3.5k doing my conversion and its still not running right. before you go throwing anything in your engine bay do the water pump and timing belt, so much easier when its out. the engine goes straigt in using the r33 engine mounts, n/a 33s run the rb20 box which bolts straight up and you just use the 33 rb20 clutch kit (excedy). next you need to get it all wired up. buy a 34 engine harness and keep your 33 one. take them to a decent sparky or get them to come to yours like i did and they can wire it all up in a day. thread loom into engine bay and then connect everything up. hook up the ecu and then your down to the smaller problems.
problems i ran into:
need to get a custom accelerator cable made up as the 33 one is too short and i belive the 34 one is too long. mine cost 130 bucks.
next problem was for some reason my neo runs the 33 CAS. you need to find out which one you need.
the vaccuum hose that runs between the plennum and the brake booster needs a bit of man handling due to the 33 one not being in the same place as the 34 but with a bit of a shove itll work.
finally dont let any of your mates that have no clue about engines help out. left one mate the job of doing the radiator hoses. didnt bother checking them cause i thought he could do a good job. 10 mins on the first drive the bottom hose came off.
in conclusion its a shit tonne of work but it is nice rocking up to car meets and when people say 'ahh dw bout it its just a boring old rb25de' you can always pop the hood and show them what you did in your driveway with limited help and knowledge.
no neos run the alloy type 33 CAS,(some late 33s had the plastic cap neo type) i have done a neo de swap because it was lying around using early ecu, ran perfectly, not saying it's ideal but does work, and not worth it unless your car is dead & you've got a free neo
Edited by WMDC35
  • 1 month later...
For those who are slightly interested haha, mechanic couldn't find anything too major wrong other then coil packs are there way out and my power steering pump has a "slight" leak and tie end bushes need replacing and front rotas need replacing ( as he's not willing to machine them) overall I'm fairly pleased with it and gives me a good start point to start fixing things
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • It would be well worth deciding where you want to go and what you care about. Reliability of everything in a 34 drops MASSIVELY above the 300kw mark. Keeping everything going great at beyond that value will cost ten times the $. Clutches become shit, gearboxes (and engines/bottom ends) become consumable, traction becomes crap. The good news is looking legalish/actually being legal is slighly under the 300kw mark. I would make the assumption you want to ditch the stock plenum too and want to go a front facing unit of some description due to the cross flow. Do the bends on a return flow hurt? Not really. A couple of bends do make a difference but not nearly as much in a forced induction situation. Add 1psi of boost to overcome it. Nobody has ever gone and done a track session monitoring IAT then done a different session on a different intercooler and monitored IAT to see the difference here. All of the benefits here are likely in the "My engine is a forged consumable that I drive once a year because it needs a rebuild every year which takes 9 months of the year to complete" territory. It would be well worth deciding where you want to go and what you care about with this car.
    • By "reverse flow", do you mean "return flow"? Being the IC having a return pipe back behind the bumper reo, or similar? If so... I am currently making ~250 rwkW on a Neo at ~17-18 psi. With a return flow. There's nothing to indicate that it is costing me a lot of power at this level, and I would be surprised if I could not push it harder. True, I have not measured pressure drop across it or IAT changes, but the car does not seem upset about it in any way. I won't be bothering to look into it unless it starts giving trouble or doesn't respond to boost increases when I next put it on the dyno. FWIW, it was tuned with the boost controller off, so achieving ~15-16 psi on the wastegate spring alone, and it is noticeably quicker with the boost controller on and yielding a couple of extra pounds. Hence why I think it is doing OK. So, no, I would not arbitrarily say that return flows are restrictive. Yes, they are certainly restrictive if you're aiming for higher power levels. But I also think that the happy place for a street car is <300 rwkW anyway, so I'm not going to be aiming for power levels that would require me to change the inlet pipework. My car looks very stock, even though everything is different. The turbo and inlet pipes all look stock and run in the stock locations, The airbox looks stock (apart from the inlet being opened up). The turbo looks stock, because it's in the stock location, is the stock housings and can't really be seen anyway. It makes enough power to be good to drive, but won't raise eyebrows if I ever f**k up enough for the cops to lift the bonnet.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
