Hi all,
just got a question regarding the diff in my R33 GTST. Basically im trying to work out if it is a stock diff or an aftermarket one.
As its a 1993 GTST I would have expected the diff to be fairly old and worn. But it has always been tight as and will even lock turning a tight corner of more than about 120 degrees.
Iv also done a bit of track work and otherwise aggressive driving and the diff will also lock under strong deceleration- i.e, shifting down to 2nd getting ready for a corner.
Is this the behaviour of a stock diff albeit in good condition or would it perhaps be aftermarket or shimmed?
cheers
https://www.sau.com.au/forums/topic/428350-r33-diff/
Seeing as the stock diff is a viscous unit that is about as solid as a bag of mouldy noodles......what do you reckon?
haha, exactly. But Im not the type to assume without decent rationale.
I suppose id want someone with extensive experience to come forth and say something like- would have to be different modified as a stock diff will not lock the rears under deceleration...
If it is also worth noting I also have a high quality synthetic oil in the diff. If that would make a difference to make a stock diff work better/ like what I am experiencing...
https://www.sau.com.au/forums/topic/428350-r33-diff/#findComment-6921352
The standard VLSD barely has any LSD action under accelaration let alone decelaration. I have driven a few and would never say the phrase "locked the gears" in relation to the way they drove.
And no. There is nothing that a different oil would do to make the VLSD seem any different. The viscous cartridge is a sealed unit. It has its own silicone fluid in it. You have to remember, the VLSD is not really an LSD in the sense that mechanical ones are. There are no friction plates/cones or ramps or any of that other stuff in there. There's just a CW&P, some spider gears, and a viscous cartridge that tries and fails to even out the torque between the two wheels (with any more than stock RB20 torque applied to it).
https://www.sau.com.au/forums/topic/428350-r33-diff/#findComment-6921398
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
