Where to start....
Well cutting a long story short. Younger brother comes home one day and says he is buying an R33 GTST.
So as competitive as brothers are, I had to buy one as well.
Skyline No 1.
The idea for this car was something fun to drive around on the weekend, hit up a couple of track days here and there.
Yeh well that didn't last long at all.
First DECA was hooked, must do more track days.
Started off with a japspec cat back, that is it. Then after a couple of track days realizing it's got to be better than this.
It became.
- fmic
- pfc
- front/dump
- cat
- greddy type s coilovers
- whiteline swaybars
- seat, harness bar and harness
- radiator, oil cooler
- diff
- better tyres (RSR's)
After that and with 190rwkw I though the thing was a rocket and I'd never have to touch it again...well.
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/
We did everything at home in the backyard, except for the engine and box swap.
The engine from No 2 went to a good home. Now in Josh's track white 32GTST.
And at the same time give the brakes a little more power.
UAS 324mm spacer.
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6925575
So that pretty much covers off 2009.
This was actually October 2009.
After russman had done a drift day and taken the front bar off on the wall.
One of the only standing start supersprints I've ever done.
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6925590
That's all for now, the exciting bits are still to come.
Gota go and work on the car :unsure:
To this stage the car is
- driven to and from the track
- on the weekends etc
- standard motor
- hypergear 21U highflow, BP98 200kw
- fmic
- diff
- 324mm brakes
- swaybars
- coilovers 8/6
- 235/45 RSR's on 17x8's
- turbo back exhaust with cat
- qfm a1rm pads
I think the year ends with
Winton 1.40
Sandown 1.27
PI 1.57
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6925594
So 2010 starts and as the year goes on
- ksport 330mm brake kit
- gtr wing
- 17x9 + 38 advan sar3 on the rear
now
- 17x8 + 35 with 235 RSR
- 17x9 + 38 with 255 RSR
Finally some grip on the back of the car!!!
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6926440
So to recap the only mods to the car are
- 17x8 and 17x9
- greddy type s 8/6
- swaybars
- 330mm brakes
- seat, harness and bar
- radiator and oil cooler
- intercooler
- hypergear 21u turbo 200kw
- cusco front camber arms
- carbon/frp bonnet
- federal 595rsr
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6926458
So reshell time again.
Found a very clean car this time around, low km.
So we kept the engine and box, the diff was also a mechanical so we left that in there.
- new radiator
- new oil cooler
- swap in suspension, brakes, camber arms, harness and bar, gtr wing, exhaust, turbo etc
- new seat (other one broke)
This time around, more grip is required.
17x9 + 22 all around
https://www.sau.com.au/forums/topic/428535-richos-r33-gtst/#findComment-6926463
    • Working through possible solutions of converting my mechanical speedo.    Anyone know what type of speedo sensor the factory r34 gtr getrag has ? what the output is ? I assume its not a VSS and more a voltage like earlier speedo sensors ? Can an ECU read it ?
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
