Hey guys have an rb25 neo.
The problem is it won't idle, feels like its lost all power.
Misfiring like no tomorrow from word go.
It's a fully built motor adjustable cam gears VCT etc.
So far..
I've changed plugs changed coil packs.
Checked harness injectors etc still no luck.
Readings from compression test:
1 50
2 51
3 50
4 50
5 49
6 53
Could the timing have jumped out and cause such low compression ?
It's also running a 2 mil steel head gasket.
thats way too low.. does it go up when you do a warm test? i spose its hard to tell if it doesnt even run.
has it been like this since it was built? have the correct pistons etc been used to work out the CR?
Do a leak down test also
Literally got it off the dyno a week and a half ago didn't miss a bear then threw an intercooler pipe off the cold side of turbo then ever since then all over the place misfiring.
Never missed a beat previously.
Motor since build has only done 20,000 tops. Doesn't get molestered either always roll on power.
When car warms up it manages to hold idle.
Still missing and gutless as all hell when accelerating but can idle.
Tried posting photos of cam gears and alignment but won't allow me to through app ...
I second that a Leak Down test would be in order.
Low compression highlights a possible leak, whether it be the valves, pistons or headgasket etc.
I put my second hand engine through a leak down test at the workshop for assurance before purchasing. It's a quick affair, and relatively cheap.
Sorry guys been hectic at work will be doing it all on Saturday correct timing first tdc compression test theneak down and hope like hell compression returns..
Definitely will post results
Yea it was freshly dyno'd as I had to fix turbo gasket. Just downloaded software for vipec and hooked in.
The tuned advanced way to far. About 6 degrees advanced basically the whole way very odd
  • 3 weeks later...
Sorry bout the late update so timing and everything's was fine.
So did a hit more hunting could not hear the click of the vct module. Found it had blown.
Replaced it and wow she's alive..
Positive things found out from jhh engineering and a few other people responsible for building this my compression is 110 which returned.
Put it back on the Dyno with a bit more boost and at 18 pound it made 518whp.
So now changing it to e85 and upgrading the supporting fuel mods.
Should be interesting.
Thank you so much to everyone's comments and suggestions.
Hopefully can create a log of my journey from unleaded to e85 (flex fuel)
    • There's plenty of OEM steering arms that are bolted on. Not in the same fashion/orientation as that one, to be sure, but still. Examples of what I'm thinking of would use holes like the ones that have the downward facing studs on the GTR uprights (down the bottom end, under the driveshaft opening, near the lower balljoint) and bolt a steering arm on using only 2 bolts that would be somewhat similarly in shear as these you're complainig about. I reckon old Holdens did that, and I've never seen a broken one of those.
    • Let's be honest, most of the people designing parts like the above, aren't engineers. Sometimes they come from disciplines that gives them more qualitative feel for design than quantitive, however, plenty of them have just picked up a license to Fusion and started making things. And that's the honest part about the majority of these guys making parts like that, they don't have huge R&D teams and heaps of time or experience working out the numbers on it. Shit, most smaller teams that do have real engineers still roll with "yeah, it should be okay, and does the job, let's make them and just see"...   The smaller guys like KiwiCNC, aren't the likes of Bosch etc with proper engineering procedures, and oversights, and sign off. As such, it's why they can produce a product to market a lot quicker, but it always comes back to, question it all.   I'm still not a fan of that bolt on piece. Why not just machine it all in one go? With the right design it's possible. The only reason I can see is if they want different heights/length for the tie rod to bolt to. And if they have the cncs themselves,they can easily offer that exact feature, and just machine it all in one go.
    • The roof is wrapped
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
