hey guys just stripped my forged 30det to inspect before it goes in, i just ordered arp head studs and was wondering what a good head gasket would be?? i found a 1.1mm cosworth one pretty cheap, would this work or should i use a genuine 30 or 26 one??
it also has an N1 oil pump in it with 2mm middle restrictor, 1.8mm rear and the vct feed is 1.65mm, would i need smaller?? it has an external head drain fitted aswell, cheers guys
In the RB30 DOHC guide is says if you have an rb25 head to use two 1mm restrictors and if you are using an rb26 head you use 1x 1.5 mm restrictor, i think i read sydney kidd wrote somewhere that you can just block off one but dont quote me on that.
Anyone know where you can get the restrictors from?
You don't have a 'head drain', you have a crankcase ventilation pipe. Restricting oil to the top end of a hydraulic head is a fairly silly thing to do. If you have converted to solid lifters or have the Neo 25 head, then this is not so much a problem. They need the quantity of oil in the head for a reason and this was designed into them because smart people know what they are doing. The absolute best thing you can do to stop oil from venting into catch cans is to have adequate ventilation from the crankcase (block) and adequate baffling in the cam covers. I would suggest an RB26 cam cover changeover and fit the Mines or Hi-Octane baffle kit. This kit, along with your ventilation pipe is all you need.
If you must bang restrictors into your block, just use the Tomei ones. They bring the size from 2mm down to 1.5 which is a substantial decrease in oil quantity.
im only worried about the oil control because it has an n1 pump which increases presure and flow, even with the restrictors it will have plenty of oil to the lifters i just dont want it pumping it all into the head at sustained high revs, plus this is all precaution i havent ran this setup yet hence why i wanna get it right the first time!! at this stage im more worried about what head gasket to use
I don't have any experience of the Cosworth head gasket but I don't think its critical so long as both surfaces are flat. I am using a Tomei 1.5 gasket.I don't like those "head drain" fittings - I have two breathers on the sump. Read the last few pages of this:<br />http://www.skylinesaustralia.com/forums/topic/110680-oil-control-in-rbs-for-circuit-drag-or-drift/?hl=sk%20oil%20control<br /><br />I have an N1 pump in my RB30/25 and use 2 x 1.0mm restrictors (you can buy them from me).
well the cosworth seems similar spec to the tomei, still multi layer and cheaper, the only reason i was looking at it cuz its about the thinest i can find which is what im after cuz my forgies are at 8.1 so i wouldnt mind squeezing just a touch more, plus the heads gunna get a skim and its on e85 so the comp will work, i hear lots of ppl saying there not fans of the head drains why is that?? how do i go about purchasing two 1mm restrictors off ya mate??
  • 1 month later...
im guessing the drains as people call them, aren't liked when people don't do them properly...
or have no idea what they are for..they are not to drain oil back...
its -16 in size(not -10 or some f**king shit) with one or 2 of them from rocker cover to sump done properly...
one usually does the trick
cheers
darren
Edited by jet_r31
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
